Is there a V7 88590715 DTC: P0037 fix?
The following post should help you disable the HEATER CEL (P0037).
https://www.evolutionm.net/forums/7302686-post267.html
<table name="Heater CEL" category="Rear O2" address="2DAFB" type="2D" level="2" scaling="blobbits">
<table name="Bit values" type="Static Y Axis" flipy="true" elements="8">
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>Rear O2 Heater CEL Enable</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
</table>
</table>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
<data>N/A</data>
</table>
</table>
edit: same info he posted above
Try clearing the ECU by removing the positive battery terminal for a few minutes and then see if the CEL returns after a few driving cycles.
Do you have the "Enable RearO2 Simulator" option enabled in your "Tephra Mod Options"?
Attached are the settings I have in my ROM:
I added the code you listed, checked my maps and I "think" it's finallly working! Thank you very much sir. I didn't realize I had to [ the 1 in the heater CEL enable box. This is my first patch besides V7 that I have ever applied.
johnnnyjeans
Cobb AccessPORT
Apr 29, 2012 09:00 AM
R717
Mar 29, 2012 12:36 PM
BadazzCR
Aug 23, 2008 07:40 AM
