Starting problems after injector scaling
#31
This is another classic sign of too rich. I know you've leaned it out and it didn't help. Lean it out more.
#39
I have a BBK Full on order and have narrowed my injector choice to PTE 1000cc's, after the recommendation by CBRD. So you're saying it won't work as smoothly, if I just use the scaling values here?
Originally Posted by Testudo
PHP Code:
PTE 1000cc
Scaling 725
Latency
3.312
2.186
1.281
0.771
0.458
0.283
0.172
https://www.evolutionm.net/forums/ec...upermerge.html
PHP Code:
PTE 1000cc
Scaling 725
Latency
3.312
2.186
1.281
0.771
0.458
0.283
0.172
#40
I cant say it will or wont. Each car is different along with each set of injectors. In my case startup could be improved but its work in progress. The scaling i used with my injectors was 886, 725 wouldnt work at all.
Fuel trims look good according to the formula i have in evoscan usually around +/- 2%
BRANDONBALDY
Aug 20, 2016 08:04 AM
derekste
28
Aug 17, 2010 07:45 PM
