Grimspeed BCS help!!!
Hey guys so I attempted to tune the Grimspeed BCS the other day and I basically gave up and put back my MBC. Every gear except 3rd would boost over 30psi, 3rd only 20psi no matter what I changed. I read both threads on tuning a 3-port but I had no luck at all. What could be my issue? I'm pretty sure i installed everything right, I left the first port without a line since I don't have a stock intake to route back to. Please help I would really like to get this working.
Thanks guys
Thanks guys
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Thanks guys
Thanks guys
Originally Posted by merlin.oz
Evo Kid, did the GrimmSpeed BCS require significantly less WGDC than the GM for a good result? I would like some feedback and numbers for the guide if possible.
Here is my review
Hey guys thanks for the help, I havent pm'd anyone because I currently dont have the BCS installed and cant make any changes till this weekend, here are my setting, anything that I would change wouldnt really help, even Zero-ing out the TBEC table
Uh your BCLO is too high. Remember you add BCLO and BDEL that is the final load base that your ECU will try to seek. I see your boost cut is set for 319 so i would assume that you want your boost to be around 300-310 load. You might want to try BCLO at 140. 140+159=299 load! Try that and let us know how it works out
No im not tuning my own car lol its looks interesting though....since im in Gainesville I just play around with the map since I can only go down to Cwills shop so many times a semester...I put in the Tephra V7 myself and its perfect with the big maps and all the other features.
