Fic 2150 scaling helllllllllppppp!!!!
Old Mar 6, 2012, 09:17 AM
  #61
outtanowhere's Avatar
injector scaling
Originally Posted by pizzamanevo8
i read somewhere that on the 03 you need to disconnect the battery to reset fuel trims ect. is this true? but on the newer evos you dont need too.
How do you get the injector scaling value to go pass 770 cc/min to 1624 for fic 2150,s? Am I missing something here?I have tephra mod 7.Thought my stock rom was to low.
Old Mar 6, 2012, 09:37 AM
  #62
Spec-Ops1's Avatar
hit "=" then enter 1624 then hit enter
Old Mar 6, 2012, 10:04 AM
  #63
ok thanks
Old Jul 31, 2013, 04:41 PM
  #64
MercenaryX2's Avatar
Are people still implementing the minimum IPW patch when using these injectors?
Old Jul 31, 2013, 10:35 PM
  #65
samadam's Avatar
I had to input the code. My afrs was steady at 11.5 until i used 1.040 min ipw. But now i cant get it ti idle right. On cold start its 11.0 and wont idle at all until it warms up then its at 14.7-15.5.
(scaling at 1218)
4.69-3.000
7.03-1.488
9.38-0.912
11.72-0.672
14.06-0.552
16.41-0.408
18.68-0.264
fuel trims are at -8 low and -10 mid.
mods:
gt35r turbo
stock bottom end
non ported head
tomei 280 cams 11.5 lift
super tech dual valve springs
tial 50mm bov (vta)
stock intake and throttle body
On MAF
E85
egr delete
exedy twin disk clutch
Need advice. I have the delete plug installed as well. It runs rich and have to stay on the throttle to keep it at idle. It dies when i press the clutch in. I have tried idle settings and injector settings. Please help Aaron.
Raceghost
May 21, 2016 12:37 PM
NOMIEZVR4
Feb 14, 2012 09:17 PM
RoadSpike
May 17, 2011 12:36 AM
negativegeforce
Jun 20, 2010 02:24 PM
iTune
Mar 14, 2010 10:28 PM
Quick Reply: Fic 2150 scaling helllllllllppppp!!!!
