iPad + EcuFLash ?
#76
*stretch*
The old timers still live.
My libmut code is still floating around and open source. It would be really, really easy to port that to a micro controller. That world has gotten a lot friendlier in the intervening 10 years. Somebody could very easily build an esp32 or esp8266 firmware and have a good scanner/reflasher for a few bucks that can log and talk to an ipad. All the info is there. It _could_ be a single weekend project, but I don't one of these cars anymore.
d
d
#77
T i literally have 2 esp32's sitting on my desk right now and thats almost exactly what I want to do with them. The Torque android app has some instructions for getting it talking to an arduino that I want to try and modify to work with the esp32 since it has dual cores, 3 hardware UARTs, and bluetooth built in. I'm still piecing together the hardware, and I'm just self learning how to do this stuff so its going to take more then a weekend, but these kind of projects are what motivate me to learn. I already put together arduino code to read the serial data stream from my Zeitronix ZT2 so ill probably get that working with torque first but pulling mut data into torque is my ultimate end goal.
https://github.com/donour/racepi/tre...shockhistogram
The BT and wifi radios are pretty reliable. The esp32 has massive amounts of cpu power, so long as you don't need to do double precision float work. The onboard uart should be perfect for talking to your obdii adapter. I memory services, the only trick is pulling RTS line at 5 baud.
d
#78
After playing around for quite a while, I am a much bigger fan of the IDF sdk than arduino for that platform. Here's some code that I use to collect shock velocity data on my lotus.
d
d
#80
I got a kindle fire a while ago when i thought Evoscan might get ported. It never happened but its still waiting to be used as a gauge cluster. Torque looks* like a nice developed front end for android. I don't know if there is something comparable for apple?
#82
Thank you for the tips! Based on your github we have some pretty similar interests. I have a bunch of Pi's around my house doing all kinds of different things. Your racepi looks really cool! I figured there would be at least a few traps/gotchas in getting the esp32 working, and im really grateful for the info. If/when i get this working I was planning on sharing everything with the community in a how-to (no profit motive here), it would be awesome if you would be open to letting me pick your brain if/when i do run into some speed bumps. Generally i like figuring stuff out for myself though so there wouldn't be any hand holding type stuff (hopefully) .
d
#84
