Stumped on Misfires and wandering A/F ratio
Hello everyone I'm having the worst misfire problem and I'm running out of ideas. I've already replaced the plus and tried gaps from 26 to 19 I've also replaced the Coils and wires with a COP set up. The injectors have been tested and a new fuel pump installed. I performed a compression test 151,150,146,150. And a boost leak test, It will hold about 20 psi before the compressor housing starts to leak. I intend to fix that soon but my misfires occur mostly while in vacuum so I don't believe the leak to be the cause. Another symptom is the A/F ratio seems to move all over. I get it dialed in and then an hour later it moves up or down .5 to 1.0, and even in closed loop it bounces form 13.9 to 15.6 The only thing I can think of at this point is maybe the fuel pressure regulator is failing. Is there a way to log fuel Pressure so I check that?
Anyway I could really use some ideas so Please share if ya have any!
FYI It runs on E85, Speed Density, and has 272 cams
at this point sounds like the front 02 sensor is bad....i had similar issues with my afr bouncing around like you. replace the 02 sensor and fixed the bouncing afr issue. but the sensor wouldnt cause it to misfire...do you misfire underboost at all? or just under vaccum? post up your timing map if you can.
I know it's not the front O2 sensor cause I'm Running this:
https://www.evolutionm.net/forums/ec...o2-system.html
I also checked for vacuum leaks with a smoke test and found none.
And yeah it only misfires while in vacuum. I'll post my timing soon cause I have to get on my other computer to do that.
