Evo Scan Maptracer not loading 96531706-v7
So I had Evoscan Maptracer working perfectly with 96530706-v7, but moved over to 96531706-v7 to convert to speed density. Now my logs in map tracer show up in the top portion of the map, but when I go to load the .Bin or .Hex file nothing shows up in the bottom and everything is grayed out.
I am also using Evoscan v2.6 with the Open Port 2.0 cable. Thanks for the help.
Here is the log in the graphing feature:
Here is Maptracer by clicking Maptracer from the graph:
Here is where I load the .Hex or .Bin file:
Then I double click on the data file:
And nothing shows up:
But if I select 96530706:
Everything works just like it did on the stock rom and 96530706:
I know the MAF 9417-v7 also has issues loading the map tracer. If you could find the difference you might be able to kill two birds with one stone and help out the guys on that 9417 v7 as well.
Success!!!!!!!!!!!!!!!! I finally figured it out
So I got it all figured out finally. I got the idea from the Evo Ecu Wiki http://evoecu.logic.net/wiki/EvoScan but the instructions were not quite working out for me like the wiki said. One thing that I noticed about about 95631706 v7 was that it includes TephraMOD-96530706-v7. So what I did was I followed the part of the wiki that says
Keep in mind that is for the 88590715 example on the evo wiki, so what I did was used a format from that website for 96530706 instead. The code that I used was
For what ever the reason 96531706 would not load at all without the <rom> and not without this portion of the code in the fake rom that is loaded in the EvoScan roms folder
<romid>
<xmlid>96531706</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>96531706</internalidhex>
<make>Mitsubishi</make>
<market>TDM</market>
<model>Lancer</model>
<submodel>Evolution VIII</submodel>
<transmission>6MT</transmission>
<year>2005</year>
<flashmethod>mitsukernel</flashmethod>
<memmodel>SH7052</memmodel>
</romid>
<include>TephraMOD-96530706-v7</include>
__________________________________________________ _______________
TUTORIAL
Non Working EvoScan Maptracer
Load this code into your favorite XML Editor (works, word, notpad++) and insert this code into it
</rom>
This file will be saved into your EvoScan Roms folder(C:/Program Files/EvoScan/EvoScan v2.6/ROMS)
[DO NOT PUT THIS INTO YOUR OPEN ECU FLASH DIRECTORY] and also make sure you have TephraMOD-96530706-v7 into the EvoScan Roms folder.
After you got all of that saved into your EvoScan Roms folder then you can load up your maptracer and select "Load HEX and XML files"
Find your EcuFlash Rom and double cllick it to load it
Success you now have a working maptracer (Don't mind my screen resolution Im on my netbook)
PHP Code:
* 2) Modify an XML to have no includes, just all of the scalings from the base file and the fuel and timing tables. EG:
<table name="High Octane Fuel Map - ALT" category="Fuel" address="49b4d" type="3D" swapxy="true" scaling="AFR">
<table name="Engine Load" address="6ec8" type="X Axis" elements="20" scaling="Load"/>
<table name="RPM" address="6ea0" type="Y Axis" elements="15" scaling="RPM"/>
</table>
<table name="High Octane Ignition Map 1 - ALT" category="Timing" address="49c8d" type="3D" swapxy="true" scaling="Timing">
<table name="Engine Load" address="6f2c" type="X Axis" elements="21" scaling="Load"/>
<table name="RPM" address="6efa" type="Y Axis" elements="20" scaling="RPM"/>
</table>
<table name="High Octane Fuel Map" category="Fuel" address="2dbd" type="3D" swapxy="true" scaling="AFR">
</table>
<table name="High Octane Ignition Map 1" category="Timing" address="33e9" type="3D" swapxy="true" scaling="Timing">
<table name="Engine Load" address="6f2c" type="X Axis" scaling="Load" elements="21"/>
<table name="RPM" address="6efa" type="Y Axis" scaling="RPM" elements="20"/>
</table>
PHP Code:
<rom>
<romid>
<year>2005</year>
</romid>
<table name="High Octane Ignition Map" category="Main Map Ignition Settings" address="38d4d" type="3D" swapxy="true" scaling="Timing">
<table name="Engine Load" address="3795a" type="X Axis" elements="30" scaling="Load"/>
<table name="RPM" address="3790a" type="Y Axis" elements="25" scaling="RPM"/>
</table>
<table name="High Octane Fuel Map" category="Main Map Fuel Settings" address="3874d" type="3D" swapxy="true" scaling="AFR">
</table>
<table name="Alternate Hi Octane Ignition Map" category="Alt Map Ignition Settings" address="37e4d" type="3D" swapxy="true" scaling="Timing">
</table>
<table name="Alternate Hi Octane Fuel Map" category="Alt Map Fuel Settings" address="37b4d" type="3D" swapxy="true" scaling="AFR">
</table>
</rom>
<romid>
<year>2005</year>
</romid>
TUTORIAL
PHP Code:
<rom>
<romid>
<year>2005</year>
</romid>
</table>
</table>
</table>
</table>
</rom>
</rom>
It seems that the http://www.globalshare.net/evo-mod/v...ears-Fixed.zip that is from the v7 thread calls for 94170015 and the evo7base file. I tried editing the files similar to what I did above but it doesn't seem to be working out like I though it would. I think that the fact that it calls for two separate files instead of just one like 96531706.
Im also not sure which version of 9147-v7 you are using. There is only one available from the tephra thread.
Make sure your loadcalc column is in use. Copy values over if necessary. The drop down for load (auto, etc.) does not work for me at least...Also removing extraneous xml is also good. IIRC everything after scaling. Comments as stated above are also problematic.
