EcuFlash
Reflash Connector
Old Oct 12, 2018, 12:13 PM
kaj
kaj's Avatar
When I say I was able to read without it, I mean that it was not connected. I believe the white plug only has the one wire that supplies power.
kaj is offline
Old Oct 12, 2018, 07:41 PM
logic's Avatar
The programming pin (FWE) exposed on the diag connector takes ~16V to enter programming mode, if memory serves; there's a step-up circuit that doesn't always hit that on the older OpenPort 1.x designs when battery voltage is a bit low, which is why you see a lot of suggestions in the archives of "charge your battery" when flashing fails.
You don't need it for reading; it's only used for putting the ECU into one of the programming modes. As kaj said, it can be completely physically disconnected, and reading the ROM with EcuFlash will work just fine.
If you want to write changes to the ECU, there's quite a bit more work to do than just applying 16V to FWE; there's a fairly involved rain dance that you have to perform via serial (OBD-II) as well, which EcuFlash expects to be able to do by itself via a working OpenPort cable.
(At some point, I should probably write up the flashing protocol and put it on the wiki. I'll probably leave writing the kernel you have to upload as an exercise to the reader though. )
logic is offline
The following 2 users liked this post by logic:
kaj (Oct 13, 2018), Pal215 (Oct 14, 2018)
Old Oct 13, 2018, 11:14 AM
kaj
kaj's Avatar
That makes sense, because if I don't keep my car on a battery tender (my car sits a lot) and go to do any reflashing, I get an error.
kaj is offline
Anubis7
Apr 11, 2017 05:05 AM
Alchem1st
Jan 10, 2017 06:32 PM
JRally
May 10, 2016 12:26 PM
gman_CZ4A
Oct 1, 2015 07:25 AM
tephra
60
Apr 17, 2012 09:34 PM
Quick Reply: Reflash Connector
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
