Need patch for v7 88580714 from P0125
Old Sep 8, 2010, 02:16 AM
kassir's Avatar
Hi guys can anyone help? Need patch for v7 88580714 from P0125 error
Old Sep 8, 2010, 09:12 PM
tephra's Avatar
dont do the rear02 disable (Periphey bit2 or whatever it is)
Old Sep 9, 2010, 03:49 AM
kassir's Avatar
You can explain in detail how to win the error. Bit 2 disable periphery not help. Thanks
Old Sep 9, 2010, 05:52 PM
tephra's Avatar
In ECUFlash under "Periphery", open up the "ECU Periphery0 (FAA) Bits" table.
Under bit.1 (the second last one) make sure it says "1" in the right hand column...
Old Sep 9, 2010, 11:51 PM
kassir's Avatar
Bit 1 in my next column is worth 1
Old Sep 10, 2010, 12:54 AM
kassir's Avatar
Say you have an email address, I would you throw off your file
Old Sep 10, 2010, 07:24 PM
tephra's Avatar
what thermostat + radiator do you have?
Old Sep 10, 2010, 11:49 PM
kassir's Avatar
I have the factory cooler and the factory thermostat, 30000km mileage in the car, the problem started after replacing the muffler on the 5000 km race.
Old Sep 11, 2010, 12:01 AM
tephra's Avatar
are you getting any other codes?
can you log coolant temp?
Old Sep 11, 2010, 03:11 AM
kassir's Avatar
My error says R0125 Excessive Time to Enter Closed Loop Fuel Contro, do log the temperature of cooling? What are the conditions for the log?
Old Sep 12, 2010, 09:46 PM
tephra's Avatar
if you can log coolant temp with EvoScan you might see it not getting upto temp...
Old Nov 5, 2011, 01:16 AM
Eugeny dontknow's Avatar
faa bit 1 can not be used to disable rear O2?
foxbat
May 16, 2022 02:51 AM
Ude Lose
Sep 14, 2016 05:52 AM
GeoMitsu
Jun 19, 2016 04:16 PM
bnr34rb26dett
Oct 6, 2015 01:09 PM
kubaolong
Sep 12, 2013 07:23 PM
Quick Reply: Need patch for v7 88580714 from P0125
