Logging LM-2
Old Nov 2, 2010, 02:08 PM
dxbevo9's Avatar
Logging LM-2
Hello peeps,
at my shop i use the portable innovate LM-2 to tune our customers evos and measure AFR..however i am having problems logging the LM2 in evoscan..i tried to set it up through logworks but with no success...anyone know a way around it?
thanks in advance guys.
Old Nov 21, 2010, 10:26 AM
HaVoC187's Avatar
I would also like to get more info on this.I plan on getting an email tune soon since cheapest they will tune my car here is 1645$ !! That's just crazy.
Well I have a LM-2 but also read that there are problems getting it to work with Evoscan and I really dont want to spend money on another device.
Old Nov 21, 2010, 04:40 PM
Fast_Freddie's Avatar
Does it have a serial output like the LC-1? If so I would say that the cal is similar to the LM-1 or the LC-1 maybe try checking one of those...
Old Nov 22, 2010, 05:54 AM
mt057's Avatar
What is the problem you are having? I have to load ecuflash, then connect my limitless cable, then connect my wideband to the computer. Also make sure that you have the proper com port selected. I know I probably sound like captain obivious but you have to start at the start lol.
Old Nov 23, 2010, 04:48 AM
todd6027's Avatar
could never get it to work with evoscan
Old Nov 23, 2010, 05:31 AM
fbikawi's Avatar
the problem is the LM 2 is a true USB device. it will not use a COM Port.
i had this problem a year ago, and i searched alot and posted on the Innovate Forum with no luck!
there is no simple solution. some people talked about a certain hardware cable that can be purchased from innovate to solve this problem. but i didnt follow this.
just buy an LM 1. it is still the best device to work with all softwares.
Old Nov 23, 2010, 05:57 AM
mt057's Avatar
What was the problem? It would not interface? What trouble code or faults were there.
Also a com port is simply a communication port. My com ports are usb, so maybe I missed the problem there...
I have to use an adaptor to swap from a serial output to an usb output so that I can connect to my laptop with the usb. I do not have a serial com port on my laptop. My lm1 only has serial outputs.
Old Nov 24, 2010, 02:49 AM
Danieln's Avatar
Protocol problems....
LM2 was too new for EvoScan and Hamish did not write a inbuilt driver for LM-2 like he did for LC-1 and LM-1
LM-2 logging specs are unknown as far that I know.
LM-2 is using (SDK) old ocx and old dll technology. This is not reliable and can get out of version sync when new versions come along.....
Old Nov 24, 2010, 08:24 AM
todd6027's Avatar
As above however it works perfectly with ecuedit logger
Old Nov 25, 2010, 12:03 AM
Danieln's Avatar
Yes.....EcuEdit is working because is using SDK protocols.....
If I remember correct.... these are the steps for EcuEdit:
First method:
1. Connect LM2 direct to PC using USB connection
2. In ecuEdit choose "Innovate SDK"
3. Goto to Configure external sensor and choose you USB port and other
parameters
4. Start to log
Second:
1. Connect serial cable to LM2
2. Connect connect Serial to USB connector to serial cable and PC
3. Start ecuEdit, choose "Innovate LC1/LM1"
4. Goto configure, set COM-port of USB to Serial device and set "LC-1"
protocol and other parameter
5. Start to log
Old Nov 25, 2010, 03:03 AM
leecavturbo's Avatar
lm2 has ana out doesn't it? i know its a ball ache but its only 1 wire to hook up to the ecu! you can just poke it in and secure with a zip tie for a few hours logging
Old Nov 25, 2010, 03:15 AM
Marschall's Avatar
Post search evo 8-9 from europe
HY!
I from Europe's middle I write about Hungary.
Excuse me, if bad topic and I write incorrectly, but I am not on top in English, and I write with the help of a machine translation program.
I ask the chief in order for the suitable topic to rearrange my writing.
Here into Europe we are frazzled very much losing weight from the good cars.i Evo you are 8 9 I earn ones between 2004-2006. 15.000-17.000 are cash on his neighbourhood. In a benefit the at what less mph and the WHITE colour concerned little tune. I cannot get more in a price because the transport is expensive. I would like a car like this very much.
I would like a good reliable car onto a street usage. I hope that you can help. Who knows a car like this you are for him there is a salesman and no problem to sell europa it please let him write email.
radetzkyandras@gmail.com
THANK YOU!!!!
Old Nov 25, 2010, 03:27 AM
todd6027's Avatar
think you need to buy or make another cable for analog out.
http://www.innovatemotorsports.com/x...cat=269&page=1
Old Nov 25, 2010, 09:00 AM
dam you don't even get that with it!
Old Nov 25, 2010, 12:49 PM
todd6027's Avatar
nope and id never ever ever buy another one , support of any description is also useless as Barryc and Danielm can confirm .
Quick Reply: Logging LM-2
