fuel pump low/high voltage transition table
I posted it in another thread, but its buried pretty deep, so I'm starting a new thread. I found the table that controls the transition between low and high voltage for the fuel pump. This will likely end up being very useful for the Walbro 400. So far, I've only found it for the 88590015 ROM as shown below. Post up requests for other ROMs, and I will dig them up as requested.
NOTE: This only works on factory fuel pump wiring or on a rewire that preserves a low/high voltage power arrangement such as:
https://www.evolutionm.net/forums/ev...e-circuit.html
January 14 Update
Someone asked if there was a hysteresis value. There is, but I had figured that nobody cared, so I previously omitted it. I have included it now.
Here is the entry for EvoScan to log the status:
88590015 ROM
January 14 Update
Code:
<DataListItem DataLog="Y" Color="" Display="Fuel Pump Low Voltage Status" LogReference="FuelPumpLowVoltageStatus" RequestID="9A" Eval="x bit 64" Unit="on/off" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="1" ChartMin="0" ChartMax="1" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="3fce" type="2D" level="1" scaling="Load8"> <table name="Engine Speed" address="6b7a" type="Y Axis" elements="10" scaling="RPM"/> </table> <table name="Low/High Voltage Transition Hysteresis" category="Fuel" address="1674" type="1D" level="1" scaling="Load16"/>
evo10.5t (Sep 28, 2016)
88580014 ROM:
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="3FF2" type="2D" level="1" scaling="Load8"> <table name="Engine Speed" address="6D56" type="Y Axis" elements="10" scaling="RPM"/> </table> <table name="Low/High Voltage Transition Hysteresis" category="Fuel" address="1674" type="1D" level="1" scaling="Load16"/>
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="3FF2" type="2D" level="1" scaling="Load8"> <table name="Engine Speed" address="6C82" type="Y Axis" elements="10" scaling="RPM"/> </table>
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="4556" type="2D" level="1" scaling="Load8"> <table name="Engine Speed" address="642E" type="Y Axis" elements="10" scaling="RPM"/> </table> <table name="Low/High Voltage Transition Hysteresis" category="Fuel" address="1A74" type="1D" level="1" scaling="Load16"/>
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="4568" type="2D" level="1" scaling="Load8"> <table name="Engine Speed" address="6576" type="Y Axis" elements="10" scaling="RPM"/> </table>
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="39a4" type="2D" level="1" scaling="Load8"> <table name="Engine Speed" address="5c6e" type="Y Axis" elements="10" scaling="RPM"/> </table>
