Speed Density 2.0 (3D VE Tables, Baro)
#916
#917
Updates:
Updated the IAT scaling for the all roms
Well hasn't this been a long time coming? Current roms are still in testing and being debated
Success in the patch for 3d VE maps however the persistant jitter bug still currently exists which I'm working on but likely will take a while to fix. Its more an annoyance than a real problem only happening on low loads cruising in certain situations which can if really needed driver choice avoided. It is assumed you have the xml's from the previous tephra v7 patches if not download them as marked here.
Current Roms I plan to patch:
94171715
96531706
88591715
Notes:
I've given up on the live tuning thing as I can't really grasp how the patch and the program sync up. Since it seems to be easily done by other people I'm going to leave it up to those experts to patch in live tuning.
Testing nearly complete still need some more testing
9417 Variant:
https://www.evolutionm.net/forums/at...d-94172715.bin
https://www.evolutionm.net/forums/at...d-94172715.zip
9563 Variant:
https://www.evolutionm.net/forums/at...d-96534706.bin
https://www.evolutionm.net/forums/at...d-96534706.zip
8859 Variant Rom:
https://www.evolutionm.net/forums/at...-tephramod.bin
https://www.evolutionm.net/forums/at...d-88592715.zip
XML Pack:
http://www.norcalmotorsports.org/use...OD-XMLPack.zip
94171715
96531706
88591715
Notes:
9417 Variant:
9563 Variant:
8859 Variant Rom:
XML Pack:
#924
Also wanted to add that for about a month now I have been driving in open loop full time. Set cruise areas to 15:1, overall I’m seeing slightly better fuel economy. When I stop being lazy I’m going to try to mess with timing in the low load/cruising areas maybe that will help even more.
#925
Hey guys, I'm thinking of converting to sd 2.0 to try it out and I was torn between 9653 or 9417 but after reading almost this whole thread I guess 9417 is the way to go for sd 2.0. Ive been having the lean tip in issue in closed loop using regular 9417. Open loop it runs fine. Ive been looking over the 3d rom and I have a couple of questions. When going to edit map under "map sensor kpa" it shows omni4bar selected under scaling. When going to edit map under "kpa to load" it says map sensor kpa under scaling. I'm using an Omni 4 bar map sensor. Do I leave "map sensor kpa" under scaling or change it to psi8a or psi16a omni4bar?
Also, I'm running regular sd now. Is there a way to bring over the values in the regular 2d tables to 3d ve table to at least get a starting point to start tweaking? If not, how should I go about it?
#926
#927
Hey snailspeed thanx for your answer buddy. I'm on stock injectors evo 8 with 9 turbo. Gsc s2 cams and full bolt ons. Now, on the picture I have attached youll see what I'm talking about. The scaling for map sensor kpa table is kpa oni4bar. The scaling for kpa to load table says map sensor kpa. Can you please check your rom and tell me what I have to choose there? I'm using an omni4bar. Theres different options for the Omni 4 bar. The table on the left already had omni4bar selected but the one on the right said map sensor kpa under scaling.
#928
#930
Awesome man that's what I wanted to know. So with sd 2.0 the 3d table is pretty much the load ve table and rpm ve from the original sd rom mixed into one table right? That's the only table I will have to touch? The 3d ve table. I noticed now theres baro vs kpa. Does that have to be messed with? What does it do?
