Wideband AFR dropping, hesitation, brick wall feeling
#31
well here ya go!!.. min uncompensated load @ steady throttle for sync acel/decel enrichment. Your lower load regions right around 90-110 need to have a slightly higher delta value, a value that a moderate/light incline will not exceed this. Small increments people, I hardly raised any one of those values 2 full points and it was clearly too much because, just on the other side of this issue I get a slight 3 ct when making some light accel in a slightly higher rpm band. But Ill tell ya there is 200% more drivability out of this car now.
well, as always the problem is just a matter of tuning this table so it seems for now. but it made a stark difference in AFR at light throttle. I also assume the sync acel enrichment could be tweaked, but I will try to take care of it here for now.
#32
Well ever since I plugged back in my knock sensor my car has been 10x better and this issue is GONE.....so everybody check your knock sensors! my wire is fraying and can see the insulated cable inside but still good enough till I can change it
#34
Did you check your knock sensor? Mine did this Exact same issue and that was the problem. Make sure it's connected and check it by hitting the block close to the sensor with a hammer to imitate knock and see if it registers under the knock count on your program. If it doesnt I would bet its bad or have a wiring problem or something.
#35
I'd like to chime in since we have some good tuners posting up info...I'm having the opposite issue, this car (my friend's 05 RS, typical bolt-ons) is running the stock 0011 on PTE1200's and Tom at VR is tuning it. So far there is an issue that happened on his last tune from Tamer back in September of 2010 also. During light load when the boost is between -2 and 3 roughly at part throttle the car goes pig rich, the Zeit reads in the 9's.
Can anyone offer some advice? Tom said he's never seen this. Also something to note is that he recently got in a minor front end collision and somehow the radiator fan cut into one of the MAF wires so I resoldered it. Since I can't remember if the old tune was doing this back in September could it be that one wire resoldered causing the issue? I soldered and shrinkwrapped it. At idle the AirflowHz are 50-62.75.
Thanks!
Thanks!
Last edited by 05blue8; Apr 28, 2011 at 09:12 AM. Reason: Fixed baud rate issue, see - http://forums.evolutionm.net/ecuflash/226020-mut-high-baudrates-works-62500-tested-5.html#post92
#36
Thanks!
Thanks!
#37
the problem is changing somewhat using max lean values in ecuflash, tuning in open loop. But still has a low rpm massive rich area. like 9.5 or better just driving around. I think this mass rich area, is causing excessive turbo boost at cruise. Does that sound plausable? Once it enters the rich zone i start building a couple more psi with no extra throttle opening at all.
#38
I am having the same problem. I just got my car back from David Buschur. I got a full build 2.1 4G64 block, Fully built and ported head gt3582r turbo 1200rc injectors. It has not done this before. At about 90-110 load it gos pig rich. I have tried to tune it out with adding timing didnt work. I tried to change some of the accel enrich tables and nothing works. Please help. Be specific on what tables please thanks.
Ralliartize It
May 10, 2012 08:48 AM
