Evo 8 Internal Id Not Foud
I've searched and exercised all of the newbie options.
I recently got the 1.3 Tactrix cord without the 9 pin. I have EcuFlash 1.42, & my computer is running Windows 7.
My car battery is fully charged, and I am able to upload the map 100%.
Once downloaded, I receive a message saying that I have a Unknown Rom Image & it cannot recognize any of my definitions.
I know that this car has been tuned five months ago. Would the tuner have locked me out from retrieving my ECU Rom info? I also have used ECU unlocker simultaneously, but this also does not find the defined rom.
I plan on using another computer today (windows xp); but I doubt this is the case.
Suggestions, experience, anything is appreciated.
Also, can I just inherit another rom and change my internal ID? Or must I use the one programed for my ecu?
The ROM ID may have been changed; it's a cheap trick used by some tuners to make life difficult for their customers when they decide to start tuning themselves. If that's the case, fixing it should just be a matter of just changing the ROM ID manually, and you're back in business.
If you can post the ROM somewhere, I or someone else can take a look at it to confirm, and adjust it for you if necessary. Is this for the car mentioned in your signature (2003 GSR)?
Edit: any newer version of EcuFlash should work fine with the older v1.3 OpenPort cables; I've never bothered buying an OP2.0, because I've been perfectly happy with the cable I have. sharkm87, if yours didn't work, you should have contacted whoever you bought the cable from; if memory serves Colby made a few changes in the 1.3 Ecuflash series to prevent unlicensed copies of his cables from working.
Yeah, for 2003 USDM GSR.
I'll post the rom but I wont be able to do it till 3pm. (On campus now)
As for the rom, all of the rom info is blank once loaded. Meaning that the ecu id, internal id, memory model etc.
What you are saying is that this rom was blocked by the tuning company and the internal id number was hidden or changed? Could I call them and find it out?
i would imagine that would mean you can rename any of the evo 8 xml file names to match whatever id it is...but idk..i've never ran into that before
deleted my registry, added all of the new v7 xml's into the folder. Connected the wire and here and behold I get a map loaded up. Yet I am confused because the diamaters in my loaded map look just like the pre-set map that was in my tephra download, i.e. there is nothing for me to copy over. Including my immobilzation code. Is this a problem?
rawkus123
Nov 13, 2018 08:26 PM
