bought evo, Rom on car
#46
OK...
97% idc, you are fine.
Seriously, though, stock injectors are properly sized to handle the max airflow from the stock turbo (on gasoline). I don't feel like posting the math again.
BTW, the logged idc % in EvoScan isn't actual anyway, seeing that there still is response and AFR changes up to the 120% range from various people.
#55
OK...
#56
so if the boost pills are gone can i still use the vac lines without the boost pills in them to go back to the stock solenoid or will i lose boost this way.
Also i managed to turn the MBC that it currently has, to set the boost to stock levels do i just adjust it and do a pull until it is set at 18psi?
mrfred
Feb 26, 2022 06:16 PM
bakuro117
Lancer Engine Management / Tuning Forums
56
Dec 23, 2016 12:32 AM
Mellon Racing
Feb 17, 2016 01:22 PM
