Innovate Lc-1 issues
Old May 7, 2011, 09:02 AM
03Ev0luti0n's Avatar
recently i installed an innovate Lc-1 with Digital AFR Gauge... The gauge reads the afr fine.... when i try to log it in the logworks software provided by Innovate... i get a error saying something about LM-1 and 9v battery (yes the ignition is on ACC)? It reads the Serial Com port correctly that i have attached to my Lc-1....
My second issue is evoscan logging the afr... again as i stated before the gauge is reading the AFR without any error indications.... and from eyeballing it under boost... idle.. etc it appears to be within the ball park of where it should be.... I am running the latest version of evoscan... I checked the WBD boxes in Evoscan and made sure its on Innovate LC-1.. the COM port is the correct port its hooked into (COM 6 as i used and adapter from the LC-1 15 pin out to USB Port and all the drivers are installed and "working properly" according to windows).... When i log under the "external wideband a/f ratio (WBD)" box i get a value of 0.... MY question i guess is if the LC-1 is not hooked up correctly how am i getting readings from the Gauge.. but neither of the Software programs to Log it??
Old May 7, 2011, 09:10 AM
SEEnoEVO's Avatar
I have had issues with some of the USB adapters in the past. May be something to search on. I have had issues logging with mine as of late as well but my gauge works fine.
Old May 7, 2011, 09:43 AM
im too terrified to make any adjustments in my timing maps without knowing what my wideband 02 is... its like going back to the old dsm days.. when you jsut went off of 02 voltage... FML
Old May 7, 2011, 09:46 AM
fryedchikin's Avatar
I would recommend logging via the ECU instead. It's a much cleaner and more reliable setup.
https://www.evolutionm.net/forums/ec...ial-cable.html
Old May 7, 2011, 09:56 AM
stunt2's Avatar
03Ev0luti0n
dude, I bet you have just forgotten to plug "terminator plug" into LC-1's serial-in cable
am I right ?
Old May 7, 2011, 11:25 AM
that really matters? and yes i had the lc-1 sent out for repair.. and innovate never sent it back to me.... wow... epic fail...
Old May 7, 2011, 12:16 PM
stunt2's Avatar
of course it matters
from my own experience
Old May 7, 2011, 01:33 PM
now they want $14 (8 for the unit and 6.75 to ship it) for a new one... which they forgot to send me back in the first place....
Old May 7, 2011, 03:53 PM
T-mun's Avatar
i'm guessing its the terminator plug as well.. Learn it the hard way.
Sheasta
Dec 13, 2015 04:39 PM
mrm95
11
Sep 7, 2015 06:40 PM
03Ev0luti0n
May 16, 2011 07:27 AM
evo9_jdm
May 5, 2010 12:53 AM
Evo Singh
Jan 9, 2007 10:09 PM
Quick Reply: Innovate Lc-1 issues
