stock MDP sensor formula
Hey, i'm trying to get a proper vacuum reading from the stock 1 bar MDP sensor on an evo 9 but the numbers i'm seeing are wayy off from what my zeitronix is reading.
I'm using the following formula in evoscan.
0.36*0.19347*x - 14.5
I see about 6psi of vacuum at idle on the MDP sensor via evoscan while the zeitronix shows 13 psi of vacuum.
I'm just wonder if my oem MDP sensor is malfunctioning or if my formula is incorrect.
I just took a look in evoscan, are you talking about logging the boost(MDP) or the jdm map because the MDP is 0.19348*x and the Jdm map is 0.19347*x-14.5 (at least that is how it comes)
im trying to log the stock MDP.
the default formula in there isn't correct either.
i got the formula from one of mrfred's post that i found through search.
here is the link https://www.evolutionm.net/forums/ec...estions-2.html
CardShark
Jul 29, 2011 12:35 AM
scrivs
Feb 15, 2011 12:55 AM
