"Scramble boost" with 3-port??
As far as I know, Scramble Boost is a marketing term for either a switch to enable higher boost, or variable boost per gear. You can do both on a stock ECU, at least with Tephra v7 on it.
Tephra gives you a wastegate duty cycle you can set pear gear, and also a map switch facility so you can have 2 completely separate copies of the WGDC map (and fuel/ignition). I have a switch wired up on my dash so that I can flick it and go between street (i.e. wife) maps and track maps.
And I'm using a GM 3port BCS.
