need some help with software
make sure you do not have both programs open at the same time. If you open evoscan it is going to lock on to the USB port for the Tactric cable. So then when you open ecuflash it isnt going to be able to open the port, it is already in use. Make sure in the options you have selected the correct port. Go into device manager and expand com ports, then you will see the tactric cable port. make sure that ecuflash is using that port number. Usually by default ecuflash auto detects the correct port. If your not to puter savy, then you can just uninstall evoscan, uninstall ecuflash. Reboot your pc, then install ecuflash reboot again, then plug in your USB cable and it will install the drivers. After that in the bottom right hand corner of ecuflash you will see it say USB tactric 1.3U cable, and the port. if it doesnt then that means you do not have the drivers installed correctly for the tactric cable and thus you wont be able to communicate with your ecu. After you see the cable in the bottom right hand corner then you can click read from ecu. Which will only be able to be clicked on after it has communicated with the USB cable. Then it will ask your for the type of car your connecting to, and the model. Once you select that it will begin to download your rom. You will see in the log window on the right hand side the memory registers that it is reading and the percentage at the bottom. During this process do not remove the cable or disrupt the communication to the ECU. It is very important when you are flashing the ECU to not do this. If you do you will get an incomplet load of the rom and possibly brick your ECU.
Good luck and let me know if you have any issues.
great ill try this now...thanks a million bro
Evoovasti
AEM EMS
Jan 19, 2008 08:03 AM
JamesN
Sep 11, 2007 04:18 PM
