8/9 Openport 2.0 logging via internal SD Card
I was finally able to pick one of these up from a friend of mine. I though I would post some of my settings to help anybody else who wanted to log non standard items with one of these.
At the time of writing my openport 2.0 device was on firmware 1.11.3137
Boost via JDM MAP: (I use 14.25, use what you have in evoscan)
Wideband wired into rear o2: (This is setup for LC-1)
1byte Load: (I use 1.3, use what you have in your v7 ROM)
Full Config:
Enjoy
Code:
paramname=Boost paramid=0x38 scalingrpn=x,0.19347,*,14.25,-
Code:
paramname=WBO2 paramid=0x12 scalingrpn=x,0.05859,*,7.35,+
Code:
paramname=Load paramid=0x41 scalingrpn=x,1.3,*
Code:
; sample logging configuration file for openport 2.0 ; must be named logcfg.txt and be placed in the root directory of the ; microSD card inserted in the openport in order to work ; this sample logs using the MUT-II protocol over the K-line, which works ; for many mitsubishis, including the EVO 8 and 9 ;----------------mut2---------------- type=mut2 ; you can also set an OBD pin to a voltage, ground, or a high impedance state ; the first number is the OBD pin number, the second number is the pin voltage with the following values: ; ; 8000-18000 : voltage in millivolts for OP2 Rev C and earlier ; 5000-25000 : voltage in millivolts for OP2 Rev D and later ; -1 : set pin to high impedance (default state) ; -2 : pull pin to ground ; ; keep in mind that if you are applying a non-zero voltage to more than one pin, all of those voltages ; must be the same ; the following setpinvoltage sets OBD pin 1 to ground, which is needed to enable logging on older Mitsubishis ; it is commented out as it is not needed for newer models (e.g. EVO 8/9) ; ; setpinvoltage=1,-2 paramname=TPS paramid=0x17 scalingrpn=x,0.39215686,* paramname=RPM paramid=0x21 scalingrpn=x,31.25,* paramname=TimingAdv paramid=0x06 scalingrpn=x,20,- paramname=Load paramid=0x41 scalingrpn=x,1.3,* paramname=IAT paramid=0x11 scalingrpn=x,1.8,*,40,- paramname=Boost paramid=0x38 scalingrpn=x,0.19347,*,14.25,- paramname=WBO2 paramid=0x12 scalingrpn=x,0.05859,*,7.35,+ paramname=WGDC paramid=0x86 scalingrpn=x,0.39215686,* paramname=KnockSum paramid=0x26 priority=2
Mad_SB
14
Oct 4, 2017 04:08 AM
xPRimNT
239
Jun 2, 2016 10:40 PM
Charlescrown
Aug 21, 2015 04:27 AM
005859x735, 20, 23, card, evo, file, grimmspeed, install, log, logging, mode, openport, scalingrpn, sd, usdm
