LC-1 slow response
LC-1 slow response
Has anyone noticed there lc-1 being slow to respond to afr changes, im not sure whats the issue.
I am Logging with the gps unit and previously havnt noticed a problem untill around the same time i upgraded injectors.
Now when lifting of the throttle or coming onto it after coasting there is a good 4-5 seconds before the expected reading appears.
for example after doing a pull and letting off the gas i continue to see an afr reading of 11.8 - 12.2 for aprox 5 seconds before the afr pegs due to the injectors being shut off on decel.
The same goes for applying the throttle after decel it gontinues to show afr of 50.1 for example before updating to 12.5 or whatever the true afr is at that time.
I am unsure if this is a result of the injector upgrade and subsequent scaling alterations or wether its an issue with the lc-1, it is approx 8months old and has had little use allthough recently it did throw an error 4?
Any ideas welcomed. Thanks
yes im using evoscan gps nav, with the version it came with. Thing is i dont remember having this problem initially its only just developed around the time i replaced injectors which coincedently is also around the time it threw an error 4
after the problems im having with my lc1 and evoscan (trying to get it to read properly for ~6 months now) im about to throw both out the window and go pay for a tune.
currently my reading sin evoscan are way off from what shows up in logworks.
for what its worth i put in a brand new sensor and response of the logged values seems to increase.
