Scaling maf
Old Jul 27, 2011, 07:16 AM
jonmorera's Avatar
Location: Costa Rica with business addres in Miami FL 33166
Scaling maf
This thread is to see your scaling maf acording to the mods that you have.
Some people like me, we are looking for a good scale to start depending on the mods we have made. For example my mods are GT3076R, injen intake, saco air filter.
hope your contributions
Old Jul 27, 2011, 07:41 AM
evo8426's Avatar
I use stock scalings. JMF aluminum intake pipe and Perrin filter on stock turbo
Old Jul 27, 2011, 07:58 AM
jonmorera's Avatar
I have some problems with the tuning, in idle my mixture is good, around 14-15's in the wideband, in the spool on the ECU AFR is on 15's but wideband shows 12's at full rpm on the ECU have 11's but wideband shows 10's I have some trouble getting the mixture evenly between the wideband and the data that has the ECU.
Old Jul 27, 2011, 09:14 AM
evo8426's Avatar
The numbers in the ECU are just numbers. They will not match the actual AFR you will see on the wideband. The MAF scaling will not cause the numbers to match the map and actual AFR, just adjust your fuel map little bits at a time until you reach your desired actual AFR.
Old Jul 27, 2011, 09:17 AM
gkania's Avatar
Correct... Sighs...
Old Jul 27, 2011, 01:37 PM
jonmorera's Avatar
You are right guys, I Understand, But would be nice if the number on the ecu were something close what the wideband shows so the tuning is more easy, I think that a good scaling of the maf is decisive to do that.
Old Jul 27, 2011, 05:06 PM
stunt2's Avatar
wrong
tweaking with MAF scaling table, you can pretty much get close to map afr. if actual afr is rich, lower MAF scaling at corresponding Hz's, if lean - other way round, raise it
I've matched my map and actual afr within 0.2-0.4 range. personally for me, it's more convinient for tuning, than seeing 9's in map and actual afr being say 11
Old Jul 27, 2011, 05:26 PM
evo8426's Avatar
Originally Posted by stunt2
wrong
Ok...without touching the MAF scaling my AFR map is within .2-.4 with just injector scaling
mplspilot
Dec 5, 2016 03:29 PM
r4p.t0x
Jun 29, 2014 10:17 AM
EriCS
Jun 29, 2010 08:14 PM
03lances
Nov 20, 2009 12:19 PM
project_skyline
Aug 30, 2009 06:58 PM
Quick Reply: Scaling maf
