Read from ecu error
Read from ecu error
Here is the log. I can connect just fine with evoscan. ECUflash will not connect though.
[16:45:39.300] EcuFlash Version 1.43.3252
[16:45:39.300] OS Version Windows 7
[16:45:39.300] Qt Version 4.6.2
[16:45:39.315] 62 memory models read.
[16:45:39.315] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[16:45:53.379] 301 ROM metadata models scanned.
[16:45:53.379] checksum module "subarudbw" loaded.
[16:45:53.379] checksum module "mitsucan" loaded.
[16:45:53.379] checksum module "mitsuh8" loaded.
[16:45:53.379] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[16:45:53.379] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[16:45:53.379] flashing tool "wrx02" loaded.
[16:45:53.379] flashing tool "wrx04" loaded.
[16:45:53.379] flashing tool "sti04" loaded.
[16:45:53.379] flashing tool "sti05" loaded.
[16:45:53.379] flashing tool "mitsukernel" loaded.
[16:45:53.379] flashing tool "mitsukernelocp" loaded.
[16:45:53.379] flashing tool "mitsubootloader" loaded.
[16:45:53.379] flashing tool "shbootmode" loaded.
[16:45:53.442] flashing tool "shaudmode" loaded.
[16:45:53.442] flashing tool "subarucan" loaded.
[16:45:53.442] flashing tool "subarucand" loaded.
[16:45:53.442] flashing tool "mitsucan" loaded.
[16:46:30.138] Using interface OpenPort 1.3 Universal TX2E9H6h0761bcdd9784f7dcdb2c8e09ee5eb7e138614b8c
[16:46:30.138] interface close
[16:46:30.138] unable to connect to vehicle interface.
I have the same problem with mine, and the only way I could get it to work was by using an older version of EcuFlash. Version 1.29a seems to be the last one that works for me.
http://ecurom.googlecode.com/svn/tru..._setup129a.exe
Thanks, I'm going to try that today. I will let you know if it works.
That fixed the problem. Thanks!
But the data I downloaded from the ECU is total crap... Example: When I open the fuel table everything under RPM is 6633 and the chart will have "inf" and mis crap that I know has nothing to do with the fuel table. My car is an 03 and the rom data said 05 (I assume someone has changed the ECU before I got it). I would like to reflash it but i'm not sure if the Hex data in the immobilizer section is accurate since nothing else is. Any suggestions?
04evony
Feb 7, 2015 02:30 PM
