EcuFlash
FIC 2150 Speed Den. Base Map?
Old Aug 7, 2011, 06:48 PM
benderrodriguez's Avatar
So my 2004 evo's EMS just took a dump. I'm going to try to go back to the stock ecu. I've been doing a ton of reading and I think I'm going to use the TephraMod with SD (I don't know if my AEM 5 bar will work)
If anyone would be willing to give me a basemap I would really really really really appreciate it
I have a
2.4L
FIC2150
FP3794
FP5R cams
AEM5BAr Map sensor (may have to change???)
I know this is asking allot, but any help would be really awesome.
benderrodriguez is offline
Old Aug 7, 2011, 08:16 PM
mullen's Avatar
hit up english racing, they have helped me out before
mullen is offline
Old Aug 7, 2011, 08:35 PM
EvoM Moderator
scheides's Avatar
Call AWDPerformance and ask for diiirk, I helped him tune their drag evo on this very setup. Here's some links to get you started:
https://www.evolutionm.net/forums/ec...ched-roms.html
https://www.evolutionm.net/forums/ec...sdm-8-9-a.html
Using the above two links (and anything linked from them) you should be able to get the car at least running and idling good, as long as you have some good latancy & scaling values for the 2150's. Might need to lower the minimum IPW as well.
TONS more links and references here, start reading and ask if you have any questions!
https://www.evolutionm.net/forums/ec...ead-links.html
scheides is offline
Old Aug 8, 2011, 09:46 AM
JohnBradley's Avatar
AEM 5 bar will work, 4 bar gets most people where they need to be. On that turbo with that engine size I doubt you will be over 44psi (the max it reads).
Aaron
JohnBradley is offline
Old Aug 9, 2011, 06:34 AM
Aaron
Out of curiosity how do people hook up the 4 Bar on an aftermarket intake manifold?
Old Aug 9, 2011, 06:38 AM
05blue8's Avatar
Companies make the map sensor adapter boss.
http://www.vividracing.com/catalog/f...-p-114424.html
http://magnusmotorsports.com/product...ap-sensor-boss
The map sensor just bolts in, run a vac hose, zip tie it up to something (the Magnus one can be welded to a manifold if you have someone that can do aluminum).
05blue8 is offline
Old Aug 9, 2011, 09:51 AM
Thanks for the info.
So does anyone mind email me a map? It would still be a huge help
Old Aug 9, 2011, 09:58 AM
JDMEvo9RS's Avatar
Just bring it to a pro tuner... That is an expensive setup to blow up on someone's free map.
JDMEvo9RS is offline
Old Aug 9, 2011, 10:02 AM
So I really want to use the tephra v7 patch of 96531706 (works on all evo8 ecus), but i don't see it listed under the AEM 5 Bar thread of supported files. I think i should try 94170015. is there info on recaling the O2 sensor? I currently have my wideband wired as my primary (front O2 Sensor)
Old Aug 13, 2011, 12:45 PM
Bump for anyone willing to help an fellow evo owner.
ch47god
Evo X Show & Shine
26
Feb 22, 2012 03:14 AM
casper03
33
Dec 23, 2008 12:19 PM
superman105
Nov 5, 2005 08:13 PM
chiquita
For Sale - Miscellaneous Automotive
Jul 19, 2005 08:46 AM
RyanM
Oct 28, 2004 10:08 PM
Quick Reply: FIC 2150 Speed Den. Base Map?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
