Going very lean up top Lots of knock tephra v7
Old Aug 14, 2011, 05:11 PM
chetrickerman's Avatar
send it to tephra, im sure he would look at it
Old Aug 14, 2011, 05:52 PM
surferjeff's Avatar
I'm sure its not the rom. Its likely the tune. It is a lot of work to tune a SD car. If it was my own, I would have hours and hours into it to get it perfected. If you are any good, you will have it ironed out. If not, get a pro tuner to work on it.
Old Aug 14, 2011, 09:05 PM
1UpMoto's Avatar
I've been tuning my evo for 5 years now, from stock turbo on stock boost to a 6262 on 44 psi....tuning isnt a problem. Like I said before I loaded my old tune with tephra v5 and it runs flawless, something is wrong with the v7.
Old Aug 14, 2011, 09:17 PM
or something could be wrong in your v7 XML file
Old Oct 4, 2011, 12:47 PM
1UpMoto's Avatar
I just wanted to update this because I think I found my issue. Well Ive been running V5 no problems but it just hit me one day that I have the gm ait sensor wired into pin 77 of the ecu and tephra v7 speed density works off of the fuel temp sensor at pin 77. I havn't had time to test it out yet but im pretty certain that will fix my problem.
jmrussell89
Oct 8, 2016 09:29 AM
onefast2gdsm
May 1, 2016 12:23 AM
WRC-LVR
Oct 14, 2015 04:12 PM
Quick Reply: Going very lean up top Lots of knock tephra v7
