few little issues
few little issues
Just converted the car to SD the other day, shes running great!.....save for a few little things.
no matter what i do, the idle is weird. its often much higher the what i'm commanding. i'm asking for 850 but it generally hangs around 1000 or 1200.
ive changed every idle table to command 850 and set the min to 800.
also, when it hangs the rev's its sitting rich(low 11's) only when the AFR leans out does it seem to drop rpm.
does any one have a VE map they care to let me use / look at?
I'm commanding 11.7afr but getting 10.9-11.3 so i assume the ve map is just wrong.
i'm still on the 2D SD mop, will be swapping to 3D tonight.
tune is attached
thanks for any help!
tune is attached
also, the big issue here......
is there no de-cel fuel cut tables?
if your under ~3500revs and you drop throttle, she goes RICH...no lean as it should.
what gives!??
what gives!??
