EcuFlash
How does my Log look?
Old Aug 31, 2011, 09:33 PM
  #46
chetrickerman's Avatar
boy oh boy. i think the only way your issue will get resolved is if someone actually comes in person and takes a loot at your engine and everything else. im out of ideas
chetrickerman is offline
Old Sep 1, 2011, 09:17 AM
  #47
desiromeo812's Avatar
Ok so I logged a bit last night ... brought boost down a bit more on the top end.. car took about 8* of timing peak and I got ZERO knock.. I will try adding another degree...I dont have the Log file but this is what it looks like, Tell me what you guys think:
RPM LOAD TIMING AFR PSI(approximate /gauge)
3000 240 4 11.7 23
3500 250 3 11.5 24
4000 265 3 11.6 25
4500 270 2 11.7 25
5000 260 2 11.7 24
5500 255 3 11.6 23
6000 240 4 11.5 22
6500 230 5 11.4 22
7000 220 7 11.2 22
7500 195 8 11.1 21
Does that look Decent enough if I cant squeeze anything more out of it?
VDR set to CF 1....310whp/ 315wtq
desiromeo812 is offline
Old Sep 1, 2011, 09:37 AM
  #48
3000 240 4 11.7 23
3500 250 3 11.5 24
4000 265 3 11.6 25
4500 270 2 11.7 25
5000 260 2 11.7 24
5500 255 3 11.6 23
6000 240 4 11.5 22
6500 230 5 11.4 22
7000 220 7 11.2 22
7500 195 8 11.1 21
was this only 1 run or did you do 3 consecutive runs?
  #49
project_skyline's Avatar
What heat range plugs you running?
Post up your maps, that would help a lot.
project_skyline is offline
Old Sep 1, 2011, 10:00 AM
  #50
I did Two runs on a completely Flat surface, and both had nothing more then 1-2 counts or knock here n there. Like I said i'm nowhere close to done with it but just wanted to post up my progress.
Old Sep 1, 2011, 10:01 AM
  #51
I am running stock Heat range plugs as those are easiest to find locally and i replaced them maybe 50 miles ago?
I will post my maps tonight when I get home! Thx for your input
Raceghost
May 21, 2016 12:37 PM
Eisen7
EcuFlash
Nov 10, 2015 01:51 PM
740 Turbo Brick
EcuFlash
11
Oct 21, 2015 05:32 PM
Thoe99
EcuFlash
18
May 11, 2011 08:16 PM
krillin
EcuFlash
15
Feb 6, 2007 10:01 AM
Quick Reply: How does my Log look?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
