EcuFlash
formula for logging KPA w/ jdm 3 bar
Old Aug 24, 2011, 05:36 PM
nonschlont's Avatar
Finally getting ready to switch to SD, and am a bit unclear as to the correct formula to log KPA in evoscan...
From what I understand, I need to edit the "JDM MAP" formula, then change psig to KPA.
Ive found a couple formulas, so looking to use the correct 1...
JDM 3 bar
1.334*x
1.7157*x-43.75
Omni 4 bar
1.6667*x
Thanks
nonschlont is offline
Old Aug 25, 2011, 02:25 PM
nonschlont's Avatar
seriously... 25 views, and no1...
I did search, thats what I came up w/... I could use a lil help here fam.
Old Aug 25, 2011, 05:29 PM
Looking at all the ancient threads from JCSBanks when he was first figuring stuff out it looks as this would be the eval from the FQ340... try it and see...
JDM 3 bar
1.334*x
Spec-Ops1 is offline
Old Aug 25, 2011, 08:57 PM
nonschlont's Avatar
Thanks for the response freddie! Just looking for the correct answer before I actually go about it...
I also forgot to mention this:
.236848*x-14.3, or is it w/out the "-14.3" (14.3) ~ sea level. In my searching, Im not finding much, and like what I said, what I did find, the formulas are different...
Its not like, Im not searching fellas... I know a bunch of u guys are tuning SD, which means youre logging KPA, and I know its something simple, Im just a rookie (I am searching!), bout to make the leap, If I can figure out how to log KPA...
My car is running great, have 0 issues, but for my knowledge, would love to learn SD, and run it on my ride... Kinda need to know how to log KPA...
Did I overlook it in a particular thread? link me, pease. Ive read them all, as far as the search engine will take me, and google for that matter...
Thanks.
Old Aug 26, 2011, 09:27 AM
Thanks.
I searched for about an hour last night and came up with NIL!
Old Aug 26, 2011, 10:04 AM
charlie.tunah's Avatar
I went the "Easy Speed Density" route, so kPA always equals load. So really no need to log kPA directly. I log airflow so I know what MAF Comp cells to tune, but thats the only SD specific logging I do.
charlie.tunah is offline
Old Aug 26, 2011, 11:51 AM
nonschlont's Avatar
thanks for the responses fellas!!! Ive been searching on and off for like 3 days now... and nothing solid.
Guess i could try the "easy speed density" route, but was hoping one of the many tuners out there that are logging KPA could chime in...
Old Aug 26, 2011, 12:08 PM
I first started with SD 2.0 and used the kPA-Load table to make big changes, then fine tuning with the RPM VE table. When switching to SD "1.0" I found John's thread and went down that route. I really like the correlation of load to boost. And using the MAF Comp table in combination with the RPM VE table, my AFRMAP is almost always within .2-.3 of logged AFR.
Im no expert, but I never really saw the need to make load match what it was on the MAF. As long as its running the timing in my map and fueling is correct, why would it matter? And its my understanding that is the purpose of the kPA-Load table...to make load match what it was.
3vo|3oost
May 7, 2017 01:10 AM
Big Bald
EcuFlash
Sep 30, 2013 03:46 PM
Dibzy360
May 17, 2013 10:02 PM
crimson red
21
Jan 28, 2011 04:11 AM
SeanV
EcuFlash
12
Dec 29, 2009 11:43 AM
Quick Reply: formula for logging KPA w/ jdm 3 bar
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
