Help Starting Idling
So I'm trying to get my car starting consistently and idle.
Quick Mod list
2.4
FIC2150 Injectors
SD w AEM 5Bar
FP5R Cams
3794
I've seen some discussion in this tread
https://www.evolutionm.net/forums/ecuflash/482329-fic-2150-scaling-helllllllllppppp.html
Currently the car barely starts and holding down the throttle I keep it running almost to 1000rpm's (93 octane)
Should I only be using the injector scaling? I know some people adjust latency but I've heard people suggest they constant parameters of the injector.
Quick Mod list
2.4
FIC2150 Injectors
SD w AEM 5Bar
FP5R Cams
3794
You should be able to get the 2150's to idle by just adjusting the injector scaling AND the latencies. I believe JohnBradley (aka Aaron) made a post with somedecent injector latency values for those injectors, just do a little searching in this section of the forum. Leave the other tables at their original settings for 93 octane.
Do you have a wideband? What is it reading when you have idling issues, is it lean or rich?
-Jamie
-Jamie
-Jamie
-Jamie
The combustion is soo erratic the wideband is going all over the place (way rich then lean)
