V7 questions
Old Sep 14, 2011, 03:05 AM
infini_IV's Avatar
V7 questions
1, Can anyone tell me what rpm/speed to gear is?? is it necassary if so what needs to be entered
2, when enabling or disabling tephra options is 1= enable and 0=disable or vice-versa
3, if im just interested in contolling boost as per factory can i just copy my tables into the BOOST ADDER LOAD, MAIN MAP WASTEGATE DUTY AND BOOST DESIRED ENGINE LOAD tables
Thanks.
Old Sep 16, 2011, 08:27 AM
AlexEvo6's Avatar
1- It's a ratio you have to determine with a quick log. Values are easy to find for 8/9 evo and 5/6 gearbox on this forum, but check after if it's works fine. I can't give my own values because I'm running a 6RS2 which are slightly different. basically, this allows to manage boost per gear (see tephra mod thread).
2 - Use tephra definition file and pay attention to the description of the bits.
3 - Yes, and all other boost-related tables
Old Sep 17, 2011, 10:43 PM
infini_IV's Avatar
Thanks for the reply allthough this hasnt actually answered anything
I realise tephra options are enabled or disabled by entering either a 1 or 0 but which way around does entering a 1 enable that option or disable that option?
As for the rpm speed to gear the car is a JDM Evo 7 GSR
Old Sep 18, 2011, 12:13 AM
dparrish's Avatar
1 is enabled, 0 is disabled.
For most of the options anyway.
Old Sep 18, 2011, 01:00 AM
FTY Motorsports's Avatar
if you dont understand that stuff you probably shouldnt be messing with it at all.
Old Sep 20, 2011, 05:35 AM
DSMolition's Avatar
Not to jack the thread but to the op. Im running v7 and evrytime I flash v7 to the ecu my car starts and dies right away(03VIII. What should i check? Thanks.
richardjh
Jul 28, 2017 03:49 PM
DormantBeast
13
Jul 9, 2017 07:38 AM
3011carlos
Oct 28, 2015 06:39 PM
07EvoIX
Oct 28, 2012 12:49 PM
therocket
Jun 29, 2010 02:43 PM
Quick Reply: V7 questions
