So a Question About Big Maps
Hey guys so I've searched but have come up empty. Is there anybody who has implemented big maps in a stock evo 8 rom? I have been running Tephra's V7 9417075 for quite awhile now but I am having some wierd idle dipping problems. I have literally flashed at least 70 different changes using suggestions from other threads on here with people having similiar issues trying to fix this problem and it either gets worse or other issues pop up but never gets better. Will dip and eventually dip far enough it cant recover and stalls. Also when I clutch in it will bounce once and usually die. Some threads I read people stated only way they could fix the idle was by switching back to the stock rom.
I have a base lancer running 14psi on a stock evo8 16g and I have flashed my settings back into a stock lancer rom and idle issue dissappears. I would like to try using a stock evo rom but really hate to lose the resolution I get with the big maps. Thanks in advance
Figured id also let you know I have done the following physically trying to fix this too:
Cleaned EGR valve
Cleaned ISCV Stepper Motor
Swapped and thoroughly cleaned intake manifold
swapped Map sensor
Swapped Vacuum control valve
checked and fixed any boost leaks
checked for exhaust leaks
Cleaned EGR valve
swapped Map sensor
Also anyone recognize what this might be? It happens about 3200 rpms. Maybe my wastegate flapper? I have been having wierd slow spool but doesnt happen always I can do a pull and hit full spool before 3000 and turn around and go back the other way and takes until 4000??
http://youtu.be/4kVQ3Ubxq9M
