V7 - Boost Cut Load
V7 - Boost Cut Load
I'm looking for an explanation of the Boost Cut Load tables functionality found under Global Boost section.
What other tables does this table work with?
Also, what are the default values?
thanks
thanks
Boost cut is just what it is.. Boost cut!.. when you reach the value in the tables at the certain rpm's your boost gets cut. Lets say you tune for 280 load at 4000 rpm.. you set your boost cut at 300... if you car hits 300 it means u are overboosting which is unsafe. therefore your boost will be cut.
This only works with ECU controlled boost, and its a awesome feature. It can save your car from overboosting and damaging something incase a line gets pinched or a boost Leak occurs
