adding launch control to my 6 TME?
Old Oct 11, 2011, 03:38 PM
shane4's Avatar
ive now got a 6 TME and also recieved my openport cable today so been having a bit of a play, managed to pull my rom from the ecu, but wanted to add in launch control, i have tried signing up to 'geekmapped.com' twice now to get the files and ask for help but i keep gettign rejected and no response from administrators, so any help is much appreciated
shane
Old Oct 11, 2011, 04:37 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
27370001?
If so:
<table name="Stationary Rev Limit"address="10878" category="Limits" type="1D" scaling="RPMStatLimit"/>
Old Oct 11, 2011, 04:44 PM
shane4's Avatar
ive adjusted the XML files, what needs changing on the ROM file?
Old Oct 11, 2011, 05:00 PM
RazorLab's Avatar
That table I listed above.
OEM value is 7969 RPM.
Set it to what RPM you would like
Old Oct 11, 2011, 08:22 PM
Benja's Avatar
Codes there but till doesn't work in my experience with both an Evo 5RS and 6GSR Bryan, the TME will be the same.
Required porting the rom to Ceddy which has coding to reference a speed below which the stationary limiter works.
Email me your rom at bjperry@gmail.com and i'll port it over and set it up for you.
Old Oct 12, 2011, 10:00 AM
Mauricio Evo IV's Avatar
Do you have a switch in clutch pedal?'
Old Oct 12, 2011, 10:06 AM
shane4's Avatar
not sure will have to look,
and email sent!
Old Oct 12, 2011, 03:36 PM
todd6027's Avatar
clutch switch not needed with ceddy rom launch control , but if you want nlts aswell you will need it
Old Oct 15, 2011, 03:54 AM
Benja's Avatar
^^^ On the money.
Email sent back Shane.
Old Oct 15, 2011, 10:23 AM
todd6027's Avatar
Originally Posted by Benja
^^^ On the money.
Sd coming soon too
Old Oct 17, 2011, 04:25 PM
shane4's Avatar
thanks for the help guys!
shane_evo7
Aug 12, 2016 02:16 PM
kylecanthurdle
May 6, 2016 01:14 PM
shane4
Oct 19, 2011 10:53 AM
tme2000
Jan 15, 2011 07:49 AM
evo6 istanbul
Sep 19, 2006 05:02 PM
Quick Reply: adding launch control to my 6 TME?
