who would pay for a
#156
Any progress on the TPMS tool? I just bought a new set of wheels/tires/tpms and would like to get them learned to my car without having to visit the dealership every spring/fall. Definately willing to pay for it!
#158
Update with ACD/AYC Bleed application
Is this available or is it work in progress ?.. What cables is it designed to work
with ? .. Will it work with the Evo 9 interface or just the CAN ?
Who would be interested in paying for a little windows application that works with your OP20 cable.
This application will just do some of the things the MUTIII does, but without having a MUTIII
So far:
- Timing Chain Elongation query and reset
- AYC Bleed
- ACD Bleed
I hope to add (but it may take a while):
- DRL disable
- TPMS disable or at least relearn
- Reinstate ECU
Thoughts?
-edit-
AYC/ACD bleed are working RIGHT NOW...
I am having an issue with the timing chain report/reset, which I wanted to get done for the first release...
If people want the AYC/ACD part, send $25USD + paypal fee to my paypal (in my sig) I will send it to you, when the timing chain bit is done I will give you a free update
Cheers
D.
So far:
- AYC Bleed
- ACD Bleed
- DRL disable
- Reinstate ECU
Thoughts?
-edit-
Cheers
D.
#160
Hi Tephra,
I have been following this thread because it was interesting. Now it may be a need for me. My AYC/ACD pump has gone bad and the dealership wants about $2K to fix it. Aside from replacing the pump, would your program allow me to do the work myself?
#163
EvoM Community Team
Start with the wheel straight, activate the bleed, turn the wheel, then go under and loosen the screw to bleed. No buddy needed. You should not be continually turning the wheel.... just turn it once and leave it there.
#165
You did it wrong. I did it that way first too. Read my other post in this thread for the correct way to do it.
