who would pay for a - Page 22 - EvolutionM - Mitsubishi Lancer and Lancer Evolution Community
who would pay for a
Old Oct 14, 2015, 06:37 AM
  #316
hispanicpanic's Avatar
A question to those that have used this tool so far.
I press the button to bleed the ACD, steering wheel is at zero degrees. I open the ACD bleeder and the fluid dribbles out very slowly. I can't hear the pump turn on when i crack the bleeder.
I do the same thing on the AYC side, and as soon as i crack the ayc bleeder, fluid gushes out like an anime hentai tentacle ****.
Is my ACD ****ed? Or is that normal?
hispanicpanic is offline
Old Oct 14, 2015, 06:42 AM
  #317
shomesomesho's Avatar
This was my exchange with Tephra awhile ago about this:
"Tephra, trying to bleed the center diff in my X using your tool. With the wheel at 0 degrees, I click "start ACD bleed" and I hear the pump kick on for maybe a second then it shuts off. Is it not supposed to run continuously? Thanks"
"It runs just enough to pressurise the system.. Mine runs for a few seconds the first time but then nothing the next time"
Hope this helps you.
shomesomesho is offline
Old Oct 15, 2015, 07:03 AM
  #318
Mine does the same on the ayc and acd. The thing that concerns me is when i crack the bleeder, the fluid barely dribbles out. Very different than the AYC bleeders that gush fluid as its obviously under serious pressure. Its almost like the acd doesn't continue to pump after the bleeder is opened.... like there's a clog or something.
Old Oct 15, 2015, 07:05 AM
  #319
Wish I could help you more. It's been so long since I bled mine and just don't remember how it acted.
Old Oct 23, 2015, 01:24 PM
  #320
Just following up: can anybody confirm if this is normal for the ACD pump to flow much less than the AYC pump when bleeding?
I am considering doing a relocation but want to hear how it's worked for others.
gfro1234 is offline
Old Oct 24, 2015, 09:12 AM
  #321
To turn on the acd circuit, you have to hit the button, then turn the steering wheel, just like you do with ayc except it doesnt matter which direction you turn.
Service manual says how to do it.
Solarwater is offline
Old Oct 24, 2015, 09:48 AM
  #322
acd bleed instructions say nothing about turning the wheel. In fact it says explicitly to keep wheel at 0 degrees steering angle. Are you saying the instructions are wrong?
Old Oct 25, 2015, 07:03 AM
  #323
From the 2010 service manual. Start at straight ahead, and then rotate one direction or the other to turn on the pump.
I have done this successfully, how I did it was wheels straight ahead, engage acd bleed with software tool, gradually turn wheel I believe about 90 degrees, then get under and open the bleeder. Fluid now comes out fast, so make sure you keep the reservoir filled.
Old Oct 26, 2015, 07:42 AM
  #324
hah! I was reading the wrong instructions. That's likely my problem. Thanks
Old Nov 2, 2015, 09:19 AM
  #325
kcevo's Avatar
Getting an application error with the software. Tried PM'ing tephra but his inbox is full. I paypal'd him before for the software years ago, not sure how to follow up and get current software or a fix to the issue.
Thanks
kcevo is offline
Old Jul 6, 2016, 10:32 AM
  #326
I would like to purchase the ayc/acd software you have for the evo x. We have a shop called Superior Speedwerks and did not want to hassle with the mut 3 tool from all the nightmares people seem to have, especially at the cost of the unit. I did not see your paypal address in the signature line, so if you could direct me on where to send payment I will do so promptly.
I appreciate your time, thank you!
Bradley
dsm nexus is offline
Old Jul 6, 2016, 04:52 PM
  #327
guys - you can email me directly... <myforumname>@gmail.com
tephra is offline
Old Jul 11, 2016, 07:30 AM
  #328
Sent you an email
Old Aug 1, 2016, 09:56 AM
  #329
could anyone tell me whats the centered value on wheel angle? I think mine is off.
lapoune is offline
Old Aug 1, 2016, 05:04 PM
  #330
it should read 0 or -0 when at the straight ahead position.
if its reading 360 or -360, AND your motor has been out (or steering column on hooked) then it wasn't put back on correctly...
be VERY careful, you will damage the clockspring if you dont fix it correctly...
tephra is offline
The Following User Says Thank You to tephra For This Useful Post:
lapoune (Aug 2, 2016)
Quick Reply: who would pay for a
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
