fuel pump low/high voltage transition table
Old Jan 14, 2012, 01:37 PM
mrfred's Avatar
I posted it in another thread, but its buried pretty deep, so I'm starting a new thread. I found the table that controls the transition between low and high voltage for the fuel pump. This will likely end up being very useful for the Walbro 400. So far, I've only found it for the 88590015 ROM as shown below. Post up requests for other ROMs, and I will dig them up as requested.
NOTE: This only works on factory fuel pump wiring or on a rewire that preserves a low/high voltage power arrangement such as:
https://www.evolutionm.net/forums/ev...e-circuit.html
January 14 Update
Someone asked if there was a hysteresis value. There is, but I had figured that nobody cared, so I previously omitted it. I have included it now.
Here is the entry for EvoScan to log the status:
Code:
<DataListItem DataLog="Y" Color="" Display="Fuel Pump Low Voltage Status" LogReference="FuelPumpLowVoltageStatus" RequestID="9A" Eval="x bit 64" Unit="on/off" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="1" ChartMin="0" ChartMax="1" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
88590015 ROM
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="3fce" type="2D" level="1" scaling="Load8">
  <table name="Engine Speed" address="6b7a" type="Y Axis" elements="10" scaling="RPM"/>
</table>
<table name="Low/High Voltage Transition Hysteresis" category="Fuel" address="1674" type="1D" level="1" scaling="Load16"/>
evo10.5t (Sep 28, 2016)
Old Jan 14, 2012, 02:41 PM
donner's Avatar
88580014 ROM:
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="3FF2" type="2D" level="1" scaling="Load8">
<table name="Engine Speed" address="6D56" type="Y Axis" elements="10" scaling="RPM"/>
</table>
Old Jan 14, 2012, 03:00 PM
Dynotech Tuning's Avatar
Thank you as always, MrFred!
94170015 pretty please
-Jamie
Old Jan 14, 2012, 03:21 PM
L-op's Avatar
88840017
Code:
<table name="Engine Speed" address="6C82" type="Y Axis" elements="10" scaling="RPM"/>
</table>
Old Jan 14, 2012, 03:27 PM
donner's Avatar
-Jamie
94170015:
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="4556" type="2D" level="1" scaling="Load8">
    <table name="Engine Speed" address="642E" type="Y Axis" elements="10" scaling="RPM"/>
    </table>
<table name="Low/High Voltage Transition Hysteresis" category="Fuel" address="1A74" type="1D" level="1" scaling="Load16"/>
Old Jan 14, 2012, 03:29 PM
L-op's Avatar
96530006
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="4568" type="2D" level="1" scaling="Load8">
<table name="Engine Speed" address="6576" type="Y Axis" elements="10" scaling="RPM"/>
</table>
Old Jan 14, 2012, 03:30 PM
L-op's Avatar
Thank you very much mfred !
Old Jan 14, 2012, 07:36 PM
240Z TwinTurbo's Avatar
Originally Posted by mrfred
88590015 ROM
Code:
</table>
This shows up in ECU Flash as Load "%." Is this "Load 1byte" or some other value?
Old Jan 14, 2012, 09:05 PM
mrfred's Avatar
Its load vs rpm. Anytime load is above the load in the table, the fuel pump will be fed full voltage.
Old Jan 15, 2012, 02:49 AM
L-op's Avatar
Is there any hysteresis value ?
Old Jan 15, 2012, 05:11 AM
SkyNight's Avatar
88570008
Code:
	<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="39a4" type="2D" level="1" scaling="Load8">
		<table name="Engine Speed" address="5c6e" type="Y Axis" elements="10" scaling="RPM"/>
	</table>
Old Jan 15, 2012, 05:23 AM
dolphin888's Avatar
Question
90550001?
Old Jan 15, 2012, 06:21 AM
L-op's Avatar
Originally Posted by dolphin888
90550001?
There you go :
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="438E" type="2D" level="1" scaling="Load8">
<table name="Engine Speed" address="4ca2" type="Y Axis" elements="10" scaling="RPM"/>
</table>
Old Jan 15, 2012, 06:52 AM
Thank you and I will post results today.
Old Jan 15, 2012, 06:58 AM
tscompusa's Avatar
nice find Mychailo as always.
Quick Reply: fuel pump low/high voltage transition table
