idle issue after fic 1100 install
ok so i installed a set of fic 1100 injectors. my innovate a/f is acting up so not sure how reliable the readings are and evoscan isnt syncing up to my wideband to log a/f but anyway at idle a/f is like 9-9.9. i have tried to adjust this on fuel maps making some extreme change and only getting minor improvements/ set backs. my question is can this be an issue from latencys, i cant seem to find any good settings for 93 on the forums anywhere or what should i try next?
A quick search will give you plenty of examples. To covert from e85 to 93, multiply the scaling by 1.3.
Here's my settings. Low and mid trim hovered between 0 to -2 however your results may vary.
Scaling - 1008
Latencies
4.6875 - 5.352
7.03125 - 3.36
9.375 - 1.992
11.7188 - 1.392
14.0625 - 1.008
16.4062 - 0.84
18.6768 - 0.72
Scaling - 1008
Latencies
4.6875 - 5.352
7.03125 - 3.36
9.375 - 1.992
11.7188 - 1.392
14.0625 - 1.008
16.4062 - 0.84
18.6768 - 0.72
https://www.evolutionm.net/forums/ec...injectors.html
and yes technically u *should* only have to change the scaling, adding 30%, to get the pump settings, but you'll need to verify, by logging afr, as well as your trims.
Keep in mind the settings that work for 1 car, may not always work for others! ALL cars are different, but should be a good starting point.
There's another good thread in the evo X forums, although most of the figures relate to the X which seem to like different settings, I found travman's figures for a IX got me close FIC 1100's Experience?
If you don't make much progress tomorrow with these values, post up a log showing your fuel trims at idle.
mrfred
23
Jul 3, 2017 06:59 PM
