ecu board number - which ecu is it ?
Old Apr 7, 2012 | 12:16 PM
stunt2's Avatar
Exclamation ecu board number - which ecu is it ?
JE331B58904A
is it VIII ? USDM ? EDM? UK ?
Old Apr 7, 2012 | 12:29 PM
donner's Avatar
Originally Posted by stunt2
JE331B58904A
Both EDM and USDM VIII ecu's has the same board number, just checked as I have both ecu's. Even numbers are the same there are some small hardware differencies (like USDM ecu I have does have SAS contolr solenoid transistor while EDM ecu does not...).
In VII ecu board number is JE331B52804A.
Old Apr 7, 2012 | 12:44 PM
stunt2's Avatar
thanks for reply mate
and is there a difference between ecu pinouts as well ?
so how to know which ecu do I have ?
Old Apr 7, 2012 | 12:52 PM
donner's Avatar
In my opinion pinout is the same, not checked every single pin to be honest but difference I mentioned is just two missing components, if components were there SAS solenoid would work from same pin.
Post a picture from backside of your ecu board and I will compare to mine, should be easy to see which one it is. It might be that there is also other differencies but the one I mentioned is the only one I found when compared ecu's...
Old Apr 12, 2012 | 01:47 PM
stunt2's Avatar
I've put pics here https://www.evolutionm.net/forums/10096717-post35.html
think I've solved the problem but the comparison is still interesting
Old Apr 13, 2012 | 12:11 AM
donner's Avatar
It looks USDM ecu, the transistor I mentioned is there. Is it in original case, what is case id?
Old Apr 14, 2012 | 03:03 AM
stunt2's Avatar
no, it isn't in original case..
Old Aug 6, 2018 | 11:34 AM
tisho's Avatar
Hello, I want to buy the ECU for Evo 7 from the attached picture but I don't know does it suitable for Rally Art. Could you help me?
Thank you in advance!
hutch959
Dec 30, 2016 06:40 PM
1091x
For Sale - Part Outs
Jul 20, 2016 06:22 PM
1091x
Jul 18, 2016 12:03 PM
Sheasta
Oct 15, 2015 06:10 PM
3011carlos
Aug 12, 2015 05:42 AM
