rescaling load values ?
using V7 with big maps and wanted to rescale load values between 100-200 load to be it incremented by 10 load and not 20 as in original, in this case max load will decrase from 350 to 300 to accept added columns in table
the thing I'm thinking about, when I logged the car it hit 275 load at ~16 psi and think it'll go past 300 load when I increase boost
my question is, why it hits such high loads at only 16 psi
and
which way to rescale tables to gain some space without dicreasing max load. can I remove 10-20 load columns completely ? or to make sub 100 load incremented by 20 and not 10 ?
looking for suggestions
and
https://www.evolutionm.net/forums/ec...-viii-ecu.html
This is for the stock rom but the proceedure is the same.
Also 275 load at 16psi does not sound right at all.
If you have a 2.3 liter then it would take more airflow to fill the chambers with the same amount of boost, cams can also attribute the same.
How are you sure you are only running 16 ? Are you looking off a boost gauge or using a map sensor ? Are you running a fairly solid 275 or just a spike ?
