How to increase Boost Limit past 319 load
Old Jul 12, 2012 | 07:01 PM
richardjh's Avatar
Lightbulb How to increase Boost Limit past 319 load
Hi folks.
Here's a little something if you don't like hitting "319" ceiling on Boost Limit.
Originally posted on EvoX... now put up here too.
This patch tells the ECU to double the load-limit lookup value it's getting from the existing "Boost Limit" table. Plus, to see the "correct" value on-screen in EcuFlash, we're looking at that same table via a new scale.
Note that this doesn't raise the OVERALL load-calc ceiling (360?) - it just lets you retain a usable boost-fuel-cut system if your load sees values over 319.
If your ROM isn't covered here, just shout and I'll add it.
Evo X 52360018
Code:
  <scaling name="BoostLimitRescalePatch" storagetype="bloblist">
    <data name="Patch disabled" value="5942" />
    <data name="Patch ENABLED!" value="5943" />
  </scaling>
  <table name="Boost Limit Rescale Patch (F1 for Help)" address="198bc" category="Turbo Boost Limit - Rescaled" type="1D" scaling="BoostLimitRescalePatch" description="Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table.  Maximum load will then be able to exceed 319."/>
  <scaling name="LoadBoostPatched" units="%" toexpr="x*5/2" frexpr="x*2/5" format="%.0f" min="0" max="638" inc="2" storagetype="uint8" endian="big"/>
  <table name="Boost Limit - Rescaled" address="555b4" category="Turbo Boost Limit - Rescaled" type="2D" scaling="LoadBoostPatched">
    <table name="RPM" address="6155e" type="Y Axis" elements="9" scaling="RPM"/>
  </table>
Evo X 52370024
Code:
  </scaling>
  <table name="Boost Limit Rescale Patch (F1 for Help)" address="198a8" category="Turbo Boost Limit - Rescaled" type="1D" scaling="BoostLimitRescalePatch" description="Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table.  Maximum load will then be able to exceed 319."/>
  </table>
Evo X 52680015-22
Code:
  </scaling>
  <table name="Boost Limit Rescale Patch (F1 for Help)" address="19c68" category="Turbo Boost Limit - Rescaled" type="1D" scaling="BoostLimitRescalePatch" description="Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table.  Maximum load will then be able to exceed 319."/>
    <table name="RPM" address="6155a" type="Y Axis" elements="9" scaling="RPM"/>
  </table>
Evo X 53040010
Code:
  </scaling>
  <table name="Boost Limit Rescale Patch (F1 for Help)" address="19a74" category="Turbo Boost Limit - Rescaled" type="1D" scaling="BoostLimitRescalePatch" description="Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table.  Maximum load will then be able to exceed 319."/>
    <table name="RPM" address="61596" type="Y Axis" elements="9" scaling="RPM"/>
  </table>
Evo X 53050009
Code:
  </scaling>
  <table name="Boost Limit Rescale Patch (F1 for Help)" address="1999c" category="Turbo Boost Limit - Rescaled" type="1D" scaling="BoostLimitRescalePatch" description="Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table.  Maximum load will then be able to exceed 319."/>
  </table>
Evo X 53050012
Code:
  </scaling>
  <table name="Boost Limit Rescale Patch (F1 for Help)" address="19f04" category="Turbo Boost Limit - Rescaled" type="1D" scaling="BoostLimitRescalePatch" description="Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table.  Maximum load will then be able to exceed 319."/>
    <table name="RPM" address="617b2" type="Y Axis" elements="9" scaling="RPM"/>
  </table>
Ralliart 55570005-6
Code:
  </scaling>
  <table name="Boost Limit Rescale Patch (F1 for Help)" address="1a310" category="Turbo Boost Limit - Rescaled" type="1D" scaling="BoostLimitRescalePatch" description="Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table.  Maximum load will then be able to exceed 319."/>
  </table>
Ralliart 55590006-7
Code:
  </scaling>
  <table name="Boost Limit Rescale Patch (F1 for Help)" address="1a298" category="Turbo Boost Limit - Rescaled" type="1D" scaling="BoostLimitRescalePatch" description="Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table.  Maximum load will then be able to exceed 319."/>
  </table>
Evo X 56180001-2
Code:
  </scaling>
  <table name="Boost Limit Rescale Patch (F1 for Help)" address="19e88" category="Turbo Boost Limit - Rescaled" type="1D" scaling="BoostLimitRescalePatch" description="Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table.  Maximum load will then be able to exceed 319."/>
  </table>
Evo X 56890009-10
Code:
  </scaling>
  <table name="Boost Limit Rescale Patch (F1 for Help)" address="1c60c" category="Turbo Boost Limit - Rescaled" type="1D" scaling="BoostLimitRescalePatch" description="Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table.  Maximum load will then be able to exceed 319."/>
    <table name="RPM" address="61f58" type="Y Axis" elements="9" scaling="RPM"/>
  </table>
Evo X 56910009
Code:
  </scaling>
  <table name="Boost Limit Rescale Patch (F1 for Help)" address="1c2d0" category="Turbo Boost Limit - Rescaled" type="1D" scaling="BoostLimitRescalePatch" description="Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table.  Maximum load will then be able to exceed 319."/>
  </table>
Here's what it will look like on a 100% stock ROM, with the XML patched in ahead of the regular "Turbo" section:
To use, under the new "Turbo Boost Limit - Rescaled" heading...
- Increment the item "Boost Limit Rescale Patch (F1 for Help)" to "Patch ENABLED!" (use '+' or ']')
- Set your desired load-based boost limit values in the new table: "Boost Limit - Rescaled".
- Completely ignore the old table: "Boost Limit"
- Enjoy!
Cheers,
Rich
Old Jul 15, 2012 | 11:30 PM
crimson red's Avatar
Nice work!! Rich.
I'd like to add the patch for 56180001/5618002. Thank you.
Old Jul 16, 2012 | 07:24 AM
richardjh's Avatar
Done.
Rich
Old Jul 17, 2012 | 05:12 AM
Thanks a lot!
Originally Posted by richardjh
Done.
Rich
Old Jul 17, 2012 | 10:32 AM
itzwolf's Avatar
Any love for 56890009/5689010?
Old Jul 17, 2012 | 01:17 PM
Hiboost's Avatar
While I have to rescale on the MR's for lower load to keep clutchpacks happy, this is a nice update especially for GSR's and big turbos. Great work!
Old Jul 19, 2012 | 04:48 AM
richardjh's Avatar
Done!
Rich
Old Aug 19, 2012 | 02:57 PM
nonschlont's Avatar
Hey Rich,
any love for the 2010's? 55570006
Old Aug 20, 2012 | 08:00 AM
richardjh's Avatar
Sure, I'll put it together when I get a mo.
Rich
Old Aug 25, 2012 | 12:10 AM
richardjh's Avatar
Done!
Rich
Old Aug 25, 2012 | 01:59 PM
nonschlont's Avatar
Nice work Rich! Thank u sir!
Old Oct 12, 2012 | 11:12 AM
sgevotx's Avatar
Care to add in 52360118? Thanks in advance guy!
Old Oct 12, 2012 | 06:18 PM
richardjh's Avatar
Done!
Rich
Old Oct 12, 2012 | 08:45 PM
sgevotx's Avatar
Thanks Rich once again.
Old Oct 20, 2012 | 02:47 AM
richardjh's Avatar
Added 56910009.
Rich
