Why does 20 psi @ low rpm = more load than high rpm in SD?
Old Nov 10, 2012, 06:45 PM
211Ratsbud's Avatar
I see this all the time, if I floor it from a low RPM I hit higher load cells than if I floor it from a few thou higher. Is load calculated VS rpm?
Im trying to understand how I will make a load based boost control work, but first I need to understand what the difference in load vs psi is, let alone Im on SD so load= psi, but .. its definitley not the case!
Old Nov 10, 2012, 07:44 PM
ReaperX's Avatar
You're making the engine work harder by flooring it from a lower rpm. Someone correct me if my explanation isn't making sense as it is late and I have worked too many hours in the last 2 weeks.
There is more exhaust energy for longer the lower the rpm you begin your pull from. The difference in a pull for me from 2.5k and 3k is a difference of 10 higher load @ 500rpm sooner @ 2.5k.
Hope that helps a little.
Old Nov 11, 2012, 09:11 AM
mrfred's Avatar
Boost (and load) will slowly creep up on my BBK if I give it a good amount of gas below 2500 rpm in say 4th gear, but once the turbo hits its efficiency range, I see the same boost and load regardless of where I got on the gas.
Old Nov 11, 2012, 01:22 PM
211Ratsbud's Avatar
FMFL!!!
Ive been skimming through my SD rom and I happen to notice that my Map V was not 1;1 with my kpa. I know I changed this 1:1 before, but I must have went back to a rom one day unknowingly. This might explain a portion of the problem Ive been seeing.
redSLed
Jan 9, 2017 05:22 PM
Kaveeth
Oct 4, 2014 05:03 PM
Douglas_Hammon
Aug 16, 2012 07:22 AM
R/TErnie
Jan 24, 2011 03:25 PM
RoadSpike
Jun 29, 2010 03:48 PM
Quick Reply: Why does 20 psi @ low rpm = more load than high rpm in SD?
