Knock and extra timing tables USDM RA 53600010
Old Nov 24, 2012, 03:26 PM
kozmic27's Avatar
These are knock sensitivity tables and some extra timing tables that I didn't see in Goldens data base for the 53600010 USDM RA Rom. The scalings are the same as for other roms so I didn't put them here. Make sure you have the scalings in your xml if you are running the latest version of ecuflash so it doesn't crash when you open your map.
53600010:
Code:
    <table name="Knock Sensitivity Load Threshold" category="Knock Detection" address="561ec" type="2D" level="2" scaling="Load8">
        <table name="RPM" address="61b48" type="Y Axis" elements="16" scaling="RPM"/>
    </table>
    <table name="Knock Background Noise Multiplier" category="Knock Detection" address="59df4" type="2D" level="2" scaling="uint8">
    </table>
    <table name="Knock Background Noise Adder (SINGLE GAIN) #1" category="Knock Detection" address="5fece" type="2D" level="2" scaling="uint8">
    </table>
    <table name="Knock Background Noise Adder (SINGLE GAIN) #2" category="Knock Detection" address="59dcc" type="2D" level="2" scaling="uint8">
    </table>
    <table name="Knock Background Noise Adder (TRIPLE GAIN) #1" category="Knock Detection" address="5feba" type="2D" level="2" scaling="uint8">
    </table>
    <table name="Knock Background Noise Adder (TRIPLE GAIN) #2" category="Knock Detection" address="59de0" type="2D" level="2" scaling="uint8">
    </table>
    <table name="EGR Timing Advance" category="Timing" address="57301" type="3D" swapxy="true" scaling="Timing">
        <table name="Load" address="61580" type="X Axis" elements="9" scaling="Load"/>
        <table name="RPM" address="6175e" type="Y Axis" elements="10" scaling="RPM"/>
    </table>
    <table name="Percent Low Temp Timing Trim vs Coolant Temp" category="Timing" address="561bc" type="2D" scaling="Percent255">
        <table name="Engine Temp" address="61140" type="Y Axis" elements="8" scaling="TempFarenheit"/>
    </table>
    <table name="Mivec Intake Interpolate X Over" category="Timing" address="5e366" type="2D" level="1" scaling="ISCVSteps">
        <table name="X" address="626f0" type="Y Axis" elements="9" scaling="RPMPerMPH"/>
    </table>
    <table name="Mivec Exhaust Interpolate X Over" category="Timing" address="5e374" type="2D" level="1" scaling="ISCVSteps">
    </table>
    <table name="Mivec % intake X over" category="Timing" address="5e392" type="2D" level="1" scaling="ISCVSteps">
        <table name="X" address="6247c" type="Y Axis" elements="11" scaling="RPMPerMPH"/>
    </table>
    <table name="Mivec % exhaust X over" category="Timing" address="5e382" type="2D" level="1" scaling="ISCVSteps">
    </table>
    <table name="IAT Ignition Advance Compensation" category="Timing" address="56184" type="2D" scaling="IgnitionCompensation">
        <table name="IAT" address="61156" type="Y Axis" elements="7" scaling="TempFarenheit"/>
    </table>
Old Nov 24, 2012, 07:49 PM
richardjh's Avatar
Cool, thanks. I've just updated Golden's site.
...with all except for the four MIVEC "X Over" items - those don't currently have tables set up in the DB. I'll get to those later (if I remember, lol).
Rich
Old Nov 26, 2012, 09:07 PM
Golden's Avatar
Yeah those tables are setup, just under a different name.
Boosted Tuning
Aug 26, 2023 10:14 PM
itzwolf
Mar 15, 2022 06:18 AM
tephra
Jan 28, 2018 04:37 PM
Piper747
Oct 9, 2010 01:14 PM
AIK
10
Sep 13, 2010 02:48 PM
Quick Reply: Knock and extra timing tables USDM RA 53600010
