Log AEM UEGO in evoscan using analog output?
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
So I have done some searches and I haven't really found a "How To" yet. I'm wondering if it would be similar to MrFred's "How To" on the Innovate LC-1?
Any ideas?
Any ideas?
FYI for anyone with an AEM wideband here is the equation and a chart:
http://thefrost.net/randomfiles/tuni...F+R_O2_Sim.xls
Base equation is 0.039137255*V+10
Code:
mL 1/mL bL/mL 0.039137255 25.5511022 255.511022
I need to copy that text in the evoscan data.xml with right formula for AEM Uego to able to log by evoscan ?
<DataListItem DataLog="Y" Color="" Display="Wideband AFR" LogReference="WideBand" RequestID="12" Eval="0.05859*x+7.35" Unit="AFR" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="22" ChartMin="0" ChartMax="22" ScalingFactor="1" Notes="" Priority="1" Visible="false" />
and set MUT12 to 8409 ?
I will wire in today my uego and will try it just would be better if i know which formula is working well ?!
Set it up just like the innovate. Works the same, just need a different formula.
BTW, i also have this working the same way using an aem oil pressure gauge. If anyone is interested in the formula let me know.
I know I'm bringing this post back to life but I tried it the other day and when the car was running basically in the 14.7 gauge range evoscan was showing me in the 10's I literally applied the instructions as per Darkmitsu posts and it's just way off.
have this been solved yet? I'm about to do the same to my IX, and as I'm reading from the link above, he only talked about wiring up the "WHITE" from the gauge to pin75 on VIII, which I believe will be pin73 on IX, am i right? But, he didn't say anything about the "BLUE" (the ground wire), do we just leave it alone or we need to have it grounded "bolted to somewhere on chasis"??
Any input would be extremely helpful, Thanks
According to the AEM EMS instructions, pin 73 is Lambda #2 input for an Evo IX, which is the same as pin 75 for an Evo VIII.
