V2.9 evoscan shift data to left into logging note header is normal
My data begins in logging note column. Why is this? What the heck is going on. I need to be able to trust this program with my engine's life! Lol
It appears any spot that would be blank the data fills that column: ie if I don't log afr map aswell te next item on the list slides over .
I had a similar case in which the log file .czv would get messed up, items displayed under the wrong title. That was a sign that the ecu is going bust & I had to replace it. Hopefully it's not the same case with you. I've read that the ECU has a max number of flashes before getting the memory permanently damaged & that's around 150-200 times
In my case the ecu gradually deteriorated, it stopped reading knock & the engine started audibly knocking even with conservative timing! I was forced to replace it.
Get a secondhand ecu, $100-$150 I guess...
In your case get two, you'll probably run it out of flashes in no time with all that ALS experimentations LoL
