Unable to read DTCs
Old May 6, 2013, 01:56 PM
foxbat's Avatar
Unable to read DTCs
I have recently upgraded my evoscan copy to ver2.9, but now, I'm unable to read/clear DTCs.
I've been attempting to read a DTC on a JDM evo7 but I get a "no response from vehicle ecu" message!
The DTC box is set to 'OBDII all 96-06 EVO7/8/9'
Device setup is 'Mitsubishi MUTIII'
ECU selection box is 'EFI'
Any possible solution to this issue?
Old May 6, 2013, 02:03 PM
todd6027's Avatar
check periphery 2 fca bit 0 = 1
Old May 6, 2013, 02:49 PM
foxbat's Avatar
Hmm, I don't have periphery 2 fca defined in the stock 7 JDM rom (98640014) or in version 9055 v5.1. I only have it in v7.
Is this a common issue with 7's roms?
Can I add it to the stock or 5.1 rom
Old May 7, 2013, 01:29 AM
todd6027's Avatar
sent you a pm there , try logging it first make sure it connects then try read dtc
Old May 7, 2013, 02:02 AM
foxbat's Avatar
Yes I did some data logging before my attempt to read DTCs, I also flashed a rom file. Is it a common issue with 7s?
I'd think that fca bit0 would be '1' be default... correct?
I'll add the code you sent me & see how it goes.
Thanks Todd
Old May 7, 2013, 02:34 AM
todd6027's Avatar
Thanks Todd
yep should be 1 by default , not a common issue
Old May 8, 2013, 12:31 PM
heel2toe's Avatar
I hate to state such an obvious thing but figured I would throw this out there. I used to run into the same issue a lot with ver2.8. I had to restart my laptop and then it would work fine. I have no idea why it did that or why restarting my computer fixed it but that was my experience.
Now with ver2.9 I have yet to have this issue but maybe its just a coincidence. Figured I would mention it though because its such a simple thing to do and it could be your issue.
Old May 10, 2013, 07:50 PM
detroit pistins's Avatar
I have the same issue as you with 2.8 but with 2.9 everything is fine.
sebass007
Lancer How Tos / Installations
40
Dec 28, 2020 08:20 AM
lolazour
Oct 9, 2016 03:53 PM
evo4mad
May 5, 2015 06:22 PM
cuscoevo
Jun 17, 2010 09:21 AM
evo4mad
Jun 4, 2008 06:12 PM
Quick Reply: Unable to read DTCs
