LC-1 O2 connection?
LC-1 O2 connection?
Hi,
Just bought a LC-1 kit.
Question : If I have tephra rear o2 and heater simulator, can I just get out the rear o2 and put my new O2 and the same bung or I should leave it there and weld a new bung and the pipe just for my O2?
And I to connect the power, i look in the region of the ignition switch to find and plug on the bigger red cable?
Thanks!
Thanks!
You can use the rear o2 bung as long as it's before your cat (or if it's still there) and you have the rear o2 simulator enabled in your tephramod rom, as far a power goes you can use any switched power, the LC-1 doesn't use much power. Hope this helps you out
supak111
Mar 14, 2016 09:10 PM
Evo8Emperor
Nov 4, 2007 06:24 AM
Evo8Emperor
Oct 22, 2007 06:08 AM
