ECU Flash not reading ECU? (Newb question)
Old Jun 18, 2013, 01:32 PM
ProPilot04's Avatar
Lads...
Just finally got a 1.3u.
Car is a 9MR that I'm way behind schedule on.
Silly questions first.
1. I'm supposed to connect the additional plug to the ACD thingy correct? So I have two connections to the car?
2. When I first tried to read the ROM, it gave me one of the more common errors related to low voltage. I ran the car, and read again. Now though... I'm getting "error sending kernel size".
Anyone have any advice on that? I didn't find anyone that actually solved the issue...
The car has a tune on it, so I'm quite positive that the ECU has connectivity.
Anyway... any help is appreciated.
Old Jun 18, 2013, 04:01 PM
todd6027's Avatar
down load ecu unlocker connect both plugs run unlocker then open ecuflash , hit read then select evo9 .eclipse then ok
unlocker in here
https://www.evolutionm.net/forums/ec...downloads.html
Old Jun 18, 2013, 04:40 PM
ProPilot04's Avatar
unlocker in here
Todd. Thanks, I ran the unlocker and nothing changed.
I just downloaded a new version of ECU flash (it's like 2 builds newer, same version though) and I'm going to try that.
I've heard some people say that I should try it with the car running? That seems like a bad idea though no?
Old Jun 27, 2013, 12:08 AM
ggian23's Avatar
i was always told don't write to the ecu while the car is on, idk not an expert by any means but does not sound like a good idea, im having the same problem, i read my car and my buddies cars and 3 days ago, yesterday after i finished the patch and map it wouldn't connect, drove the car, let it warm up, charge up, nothing, it randomly connected to mine but not my friends and it wont read mine either now... just frustrated as hell now... all evo 9's same ecu ids. need help bad!!!!
Old Jun 27, 2013, 12:45 AM
AndyCT9W's Avatar
I read my ECU with my car running. It just turns off and starts the read, I think it has something to do with the voltage reading being higher.
As for writing the ECU with the car running? I imagine the same thing would happen but I haven't tried so I don't actually know.
rawkus123
Jul 20, 2017 05:19 AM
fabiangt79
May 8, 2012 12:15 PM
silex
Mar 15, 2010 04:47 PM
mike86
Jan 20, 2010 07:04 PM
supersnow
Jun 2, 2007 08:07 PM
Quick Reply: ECU Flash not reading ECU? (Newb question)
