Fuel Cut and Load Limit removal for EVO 9 SD Tephra???
I have an EVO 8 map which has an option under Global fuel "Set to 9 to remove load/fuel limit". Is there an EVO 9 Tephra Speed Density map with that option written in the code and where do I find it? I searched at least 10 different terms with no results.
I set the fuel cut limit to 638 and it's still hitting fuel cut at 34 psi. ID 2000 injectors and 2 044 pumps, so it's getting plenty of fuel, and nothing is being pushed to the edge. On the datalog you can see the injector duty cycle go to 0 when it happens. It only happens at full throttle, if you give it 75% it's fine. All the sensors seem to be working correctly, and no settings are off. I also raised the fuel cut delay to it's highest possible setting, and it helped a bit. Now it fuel cuts only half the time. I was reading about setting the ve vs. map sensor. Would this be an option? This car is being a problem child.
I also recall reading that these limits are already disabled in the SD Roms due to the way the ROM caluclates load.
