odd little issue
odd little issue
Hey guys, I'm not sure what this issue is but was wondering if you guys might be able to help me.
I recently finished my 2.3L HTA86 build, and I'm having an issue with the idle. I'm running the Tephra V7 Fuel Temp SD tune (which ran fine before the build).
Now the issue I'm having is this. My car is running rich, rich enough for me to see fuel fumes coming out of my exhaust (black smoke) at an idle. Now I just replaced my WB sensor (literally 3 days ago as it was reading 14.9 only, never fluctuated), and since the replacement, my car will jump from 14.2-14.5 to 18.0+. And it's back and forth, and won't stabilize, so I can't tell how lean or rich I'm running. Is that a fault with the tune or is my other new 02 sensor bad? I can post up a pic of my fuel maps if you'd like. I'm lost and I'd like to get this taken care of before I really start driving my car again. Thanks in advance for any help.
AEM put a video on YouTube on how to test the WB sensor.
It was running good before with the same tune on a 2.0 or 2.3L motor? Chances are that it was a 2.0 and now you have more VE with bigger displacement. You'll need a retune. First check to make sure the WB is reading right.
89turbosupra
Oct 17, 2015 03:57 PM
