Very strange WGDC behavior - 5th gear only?
once i got it to have smooth wgdc application in 5th and smoothed the timing a tiny bit the spool knock went away thankfully. im inclined to leave it where it is right now since i have a track day next week and everything is working well right now. then ill have two weeks to dial in the correction tables
right now im down a little power/torque, presumably because the afr's are richened up due to hitting a new load column, but i also may have been running more boost than i thought on the stuck mbc thats been on the car since i bought it.
the test on the top of my list is gaining back some spool, it looks like i lost 4-500rpm in spool, and i feel like i should be able to cut that in half since im only running 70% wgdc from 0-4k rpm.
killerpenguin21
Jun 7, 2013 02:23 PM
killerpenguin21
25
Apr 18, 2013 03:41 PM
